why aren't my deleted polygons staying deleted? {Accomplished, but not resolved}
WillowRavenWillowRaven Posts: 3,787
edited June 2020 in The Commons
I'm using the geometry editing tool and deleting specific sections of my forest. I save, reopen the file, and only some stay deleted. Why?
Post edited by WillowRaven on
  • felisfelis Posts: 6,600
    Are you sure that this geometry wasn't just hidden and not deleted?
    If I remember right it is a 2-step approach. First you hide the polygons, and then you delete the hidden polygons.
  • nicsttnicstt Posts: 11,715
    edited May 2020
    Because they've not been deleted; as felis says, it's a two-step process. Computers are sadly notorious for not doing what we want or what we think we've done, only exactly what they've been told.
    I'm not being flippant, merely pointing out that if something is happening that we don't expect; investigate the process we used.
    Post edited by nicstt on
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,736
    edited May 2020
    nm no longer trying to help you on anything
  • nonesuch00nonesuch00 Posts: 18,882
    Probably because you deleted some but only hid the others.
  • Richard HaseltineRichard Haseltine Posts: 111,853
    That isn't necessary now - you can select and then delete selected in recent versions of DS.
  • WillowRavenWillowRaven Posts: 3,787
    That's what I've been doing ... select and delete, then saving the file under a new name. It's only working part way. I spent all day yesterday re-doing what I did the day before.
    Do you have only the one edited version of the forest in the scene?
    I have one forest winter and one forest superior. Since it seems like roughly half of what I delete stays deleted, I'm twiddling it down with each new save as new name and re-opening.
    Final update and result ... Although I never figured out why only segments of my deleted polygons stayed deleted upon reopening of the file, I just kept removing what remained until it finally went to nothing. Here is the final result ...
    Picture Picture
