Clothing made of Genesis Character?
Hey!
Thanks for look at my post here..
For like 3 Months i am looking, more or less, for a solution to create "special" clothing, but.. i don't even know if it is clothing or maybe something else...
Let me describe it please, with my poor english..
There was a Robot, with Assets or whatever (clothing?), it was called "Aurora Bot" from "Ion".
Sadly i can't find it here at the Daz Store anymore, so i couldn't ask him how he did, whatever he did.
At first i did load my Genesis 3 into the Scene, right after i load something called "Mech". It is like clothing, but..
When i hide this clothing, then parts of the character get invisible.. so it is not like common clothing. Anyhow it does replace the characters body parts i guess...
My Question is, how the heck this works?
I did see and understand, he was creating this "Mech" out of a Genesis 3 Female Body, then he maybe saved it as OBJ and importet it as clothing to DAZ.
I can't find any tutorials wich are showing me "exactly" this. All other clothes are used as... clothes ... yes.. but this one here replaces the body itself anyhow.
Please look at the Pictures i've attached here.
I need to know how he did this, becasue i wan't try creating also such a robot for Genesis 8.
There is something similiar, it is called "Genesis 8 Genitals" but i guess its available at "Renderosity?".
It looks the same, like the Author took a Genesis 8 Female, cut off everything and just used the Lower Body Part and saved it anyhow as clothing? At least it also replaces the body.
The Pictures show you what happens if i hide the Mech or the Genesis 3 Character.
I hope you understand, i am at the end with my Latin, i simply don't understand how it replaces the body.
If i attach this mech to a Genesis 8 Female, it won't work, because it seems it cannot replace the body then. Same for Genesis 2. (Look Picture Nr 3) It won't replace the body, even it fits, and so i have this clipping issues...
Regards,
- Sam
  • So, I see the figure on RenderHub.
    The description says that the parts are "Geo-Grafted". These are not clothing pieces. They are separate items that replace part of the figure's mesh.
    These are, like the Anatomical Elements, specific to the Generation that they are intended for. I don't know of a way to apply the Geo-Grafts across generations.
    In this case, since it's Genesis 3, I wouldn't be able to apply it to Genesis 2 or Genesis 8.
    Maybe someone else knows how to Geo-Grafts compatible, however.
  • KhajiirahKhajiirah Posts: 10
    At RenderHub?
    He is there, i totally did forget about RenderHub, i will contact him and thanks for your reply. "Geo-Grafted" is also a help, i will look it up then!
    Thanks!
  • Silent WinterSilent Winter Posts: 3,965
    edited May 2020
    This vid explains a bit about geografts:
    (he makes a hole through G3M's body but the principle is the same for other addons).
    My chess set for G8 is made using geografts (link in sig)
    Post edited by Silent Winter on
