DELETE
davesodaveso Posts: 7,908
edited October 2021 in The Commons
DELETE
Post edited by daveso on
  • FishtalesFishtales Posts: 6,218
    If it is above the horizon and in front of the camera then yes. You can also change the disc size so that it looks bigger.
  • davesodaveso Posts: 7,908
    edited October 2021
    DELETE
  • You can set the direction of the sun using a camera: In the "Render Settings" tab select "Sun-Sky Only" under the "Environment Mode" dropdown. Then click on "SS Sun Node" and select a camera that you have created for this purpose. Wherever in the scene you place the camera, that will set the direction to the sun as the ray from the scene origin through the camera position.
    Set the Lat/Long, month and time to where you live. You then know where the sun is going to be in the sky so you can point the camera towards it.
  • dennisgray41dennisgray41 Posts: 860
    what about declination.
    If I set everything for where I live I know where the sun should be in the sky just by looking :)
    edited October 2021
    DELETE
  • Silent WinterSilent Winter Posts: 3,898
    Why not use the sun-dial in the render presets? Then point it where you want it. (Or use a distant light and set it as the sun-node in render settings so you can look through that  to get the angle you want)
    edited October 2021
    DELETE
  • AlmightyQUESTAlmightyQUEST Posts: 2,006
    If you are using a camera as the view node and the sun is not in line with the camera line of sight, make sure the dome rotation value is zero. I use the camera to specifically direct the sun frequently.
    edited May 2020
    I dont see any sundial things in render setting. Tried the distand light theng, but that is not making sense to me. ended up somewhow screwing the entire scene up. Also up above tried the deal with the sun node to the camera, but the sun was coming from the side then, not the front.  I can't even see the dsun any longer for whatever reason, although I have not changed any of the settings for the environment or sun ... the disk is not visible.
    Sun-dial should be under: Content/My Library > Render Presets Iray (not the render settings tab) - once loaded in the scene, expand the tree to get to the 'Sun Chain' bone.
    For the distant light - create one, then in the render settings tab, go to 'Environment' (make sure it's on 'sun sky only' then scroll down to 'SS Sun Node' - it'll start as 'none' - click that and select your distant light). (Edit: Just tried it and I largely get a too-bright sky but if I lower it near the horizon I can see the sun)
    Post edited by Silent Winter on
  • DMaxDMax Posts: 637
    Somewhat on a similar topic, when I use "Sun and Sky", all the spotlights in my scene are switched off. Does "Sun and Sky" thus mean that ALL the lighting for the scene will ONLY come from the sun and the sky? I was happy to use a sun and sky setting to a certain date/time but then my spotlights were all turned off so in the end I had to substitute "sun and sky" with "dome and scene" and applied an HDRI background.
    ^You can still use emissive lights but otherwise 'Sun Sky Only' turns off other scene lights (AFAIK). If you remove the HDRI from the Environment tab, it'll then use the same 'Sun Sky' node but now you can have 'dome and scene' to use your scene lights too.
    edited May 2020
    These use the sun from the dome.
    Whale
    Click on image for full size.
    Winter Solstice
    1920 x 1080 - 1M
    1920 x 1080 - 1M
    Post edited by Fishtales on
  • nonesuch00nonesuch00 Posts: 18,795
    Yes, you need Dome & Scene instead. You can still set the time, date, and GPS coordinates though.
    edited October 2021
    DELETE
    edited October 2021
    DELETE
    edited May 2020
    daveso said:
    Whale
    Winter Solstice
    that sun in the whale image is perfect. wow. I'm still working on it laugh  figured out that if I start over, new scene, it is much easier to find the sun, then put out my props  and figure in realtion to that.  It works for me for now.
    I made a mistake. The whale one uses a HDRI, I just checked. This one does use Sun and Sky though smiley
    Out of the Sun
    1920 x 1080 - 833K
  • nicsttnicstt Posts: 11,715
    You don't need declination if you set all detailed.
    edited October 2021
    DELETE
    edited May 2020
    daveso said:
    Fishtales said:
    daveso said:
    Whale
    Winter Solstice
    Out of the Sun
    this one even better :)  where do the coulds come from? So many things to learn
    Those are cloud billboards from another set.
    1292 x 767 - 283K
    daveso said:
    Fishtales said:
    daveso said:
    Whale
    Winter Solstice
    Out of the Sun
    These are the settings.
