disolve Dialogue ? (SOLVED)
Sal UK
is there anything I can do to make it appear again?
I hit disolve and it just deletes the lines and leaves the points behind I want to disolve all but the dialogue box has stopped apearing I have reset settings and restarted and reloaded what I am working on but still not showing the dialogue, it did when I used it before well a few hours ago but now nothing... :(
Thanks for any help!
Sal.
Post edited by Sal UK on
Are you hitting the delete key rather than the backspace key, it is easy to get mixed up sometimes, if you validate a check mark against the display command viewer under , edit/preference editor/user interface/misc, it will bring up a little indicator in your view to help remember keyboard short cuts.
Dissolve is also under the edit menu.
hi TapiocaTundra
Thanks for the reply, No actually I am using the drop down menu under edit. Its strange as it worked as it should and all of a sudden had to use disolve again but no dialogue came up. I have heagon on my laptop also and works fine on there maybe Ill put my work on a mem stick and finish it on the laptop.
I thought maybe I had hit a key that turned off popup dialogues but I reset everything to default and restarted hexagon and the computer after a hard reset but still the same.
Sal.
Solved it by re-installing Hexagon... :)
Sal.
