Hair Conversion M to F and reverse
Hello,
I'm noticing that sometimes when using a hair product, the pose controls go away when the product wasn't made for the exact figure being used (usually from F to M.) Are there any converters out there to handle a change from F to M and the reverse? I have both the Hair Converter's from G3F to G8F and G3M to G8M. I just want to go between the genders.
Thanks
Illy
  • zombietaggerungzombietaggerung Posts: 3,848
    If it's long hair just change the Scene Identification, then fit as normal.
  • Phoenix1966Phoenix1966 Posts: 1,846
    edited May 2020
    If that doesn't work for you, there are these products:
    https://www.daz3d.com/genesis-8-cross-figure-resource-kit
    https://www.daz3d.com/genesis-3-cross-figure-resource-kit
    You can also just load the hair without the figure selected and then parent it to the head, too.
    Post edited by Phoenix1966 on
  • ArtsyDragonArtsyDragon Posts: 682
    Hello, I'm not sure what this means: 'change the Scene Identification.' Can this be elaborated upon?
    Thank you. I have the first product. I'll take a look at it. I'd forgotten about it.
  • The Blurst of TimesThe Blurst of Times Posts: 2,410
    edited May 2020
    Each conforming object hss a Scene Identifier, so that it knows what to associate that item with.
    The limited difference between Genesis 3 and Genesis 8, along with Male/Females within that pool, have allowed some people to simply change that Scene Identifier tag to apply Hair/Clothing in the entire Genesis 3/8 pool especially to Genesis 8 figures. It get s a little wonky with the T/A pose difference, but there are ways around it if you look on the forum.
    Anyway, load the Hair into the scene, then Edit -> Object/Figure -> Scene Identifier. Just flip it to your preferred model and then try Fit To...
    Post edited by The Blurst of Times on
  • FSMCDesignsFSMCDesigns Posts: 12,844
    The attached image gives you an idea where to go to do it
    846 x 378 - 69K
    What they said.
  • scorpioscorpio Posts: 8,533
    You can also just parent it to the head rather than fitting to
