Hair Conversion M to F and reverse
Hello,
I'm noticing that sometimes when using a hair product, the pose controls go away when the product wasn't made for the exact figure being used (usually from F to M.) Are there any converters out there to handle a change from F to M and the reverse? I have both the Hair Converter's from G3F to G8F and G3M to G8M. I just want to go between the genders.
Thanks
Illy
  • zombietaggerungzombietaggerung Posts: 3,942
    If it's long hair just change the Scene Identification, then fit as normal.
  • Phoenix1966Phoenix1966 Posts: 2,001
    edited May 2020
    If that doesn't work for you, there are these products:
    https://www.daz3d.com/genesis-8-cross-figure-resource-kit
    https://www.daz3d.com/genesis-3-cross-figure-resource-kit
    You can also just load the hair without the figure selected and then parent it to the head, too.
    Post edited by Phoenix1966 on
  • ArtsyDragonArtsyDragon Posts: 682
    Hello, I'm not sure what this means: 'change the Scene Identification.' Can this be elaborated upon?
    Thank you. I have the first product. I'll take a look at it. I'd forgotten about it.
  • The Blurst of TimesThe Blurst of Times Posts: 2,410
    edited May 2020
    Each conforming object hss a Scene Identifier, so that it knows what to associate that item with.
    The limited difference between Genesis 3 and Genesis 8, along with Male/Females within that pool, have allowed some people to simply change that Scene Identifier tag to apply Hair/Clothing in the entire Genesis 3/8 pool especially to Genesis 8 figures. It get s a little wonky with the T/A pose difference, but there are ways around it if you look on the forum.
    Anyway, load the Hair into the scene, then Edit -> Object/Figure -> Scene Identifier. Just flip it to your preferred model and then try Fit To...
    Post edited by The Blurst of Times on
    The attached image gives you an idea where to go to do it
    846 x 378 - 69K
    What they said.
  • scorpioscorpio Posts: 8,533
    You can also just parent it to the head rather than fitting to
