do some outfits just not have a smoothing option?
alan bard newcomer
trying to work with the new retro space suit
and it's a little short on top of the shoulders
but before I start resizing outfits etc
I just check for smoothing and I can't find
it...
(and I do have hidden properties checked )
thanks.
Okay, does look there's no mesh smoothing showing up .. could it be hidden?
first illustration retro space suit second a pair of pants from the same scene and it shows a mesh smoothing line
Post edited by alan bard newcomer on
Some do, some don't, but, you know, you can add one. Edit -> Figure -> Geometry -> Add Smoothing Modifier. Usually works well with Hiigh Resolution mesh. If there is none you can Edit -> Figure -> Geometry -> Convert to SubD.
thanks.. litereally I think it's the first time I've ever hit one...
was able to fix it with some of the morphing options
but it's good to know there are options beyond options.
