The I’ve Seen Fire and I’ve Seen Snow and Now I Want Cocoa Complaint Thread
1323335373850
  • frank0314frank0314 Posts: 15,111
    edited March 2014
    Frank0314 said:
    That's a neat little app. Where you get that from
    You can find it here: GPU-Z
    Cool, TY!. I run the basic desktop gadget for the gpu. This one has a lot more info
    404 x 495 - 65K
    199 x 554 - 31K
    Post edited by frank0314 on
  • kyoto kidkyoto kid Posts: 42,421
    Frank0314 said:
    Kyoto Kid said:
    ...the main folder is there but all the sub folders are empty. the only thing there is the icon file and Windows .dll.
    It's like someone went into my system through my firewall without my knowledge and deleted all the components.
    Was going to load/install the update for the Atmospheric Cameras as the fixes for the Advanced Spotlight/Ambient light are included.
    This has me just a BIT concerned.
    Are you running any kind of auto cleaning software on that computer. Is it a private ISP or Wifi Hub
    ...no. I have Norton IS and MalwareBytes but neither ever messed with the software I had installed. Not sure what "Private ISP" would be as I know nothing about setting up a network or server. The odd thing is it was there the last time I shut down, now it isn't.
    DIM committed suicide!
    Dana
    ...that's what it looks like.
  • HastyDaveHastyDave Posts: 109
    All the posts is belong to Misty!
    234 x 240 - 19K
    DO you have your own internet connection or are you using a public Wifi connection?
    As Richard suggested in the DIM thread, did you try to do an update before you shut down your system
    edited March 2014
    Sorry Misty, but the Geforce 8400 is slow by today's standards. Even the Geforce 630 is kinda slow. I read somewhere that CUDA rendering with Luxrender using the hybrid mode is still experimental or slow with low cost video cards.
    The more powerful cards that use PCI Express 16 2.0 or 3.0 are expensive at $75 or more.
    Sorry I couldn't help more.
    Edit: GPU-Z can show you what kind of video card and the PCI type. If you have an integrated video chip, GPU-Z may not show the correct PCI slot bus that you motherboard has. See the second screenshot for an example.
    I'll keep looking for a program that will display the types of slots that are in your computer.
    Thanks.
    i have an asus compy, currently with the integrated video, comes with a hdmi out. :)
    looked at the 8600, it doesn't have hdmi out.
    i hates waits for luxrenders to ungrain, iz-a-maken me crazy.
    Post edited by Mistara on
    Dana
    does it auto-update? maybe it died in the middle of a preliminary uninstall?
    All YOUR BASE BELONG TO US.
    tee hee
    i can't even remember where that line came from.
    like:
    put the lotion in the basket -whats it supposed to mean?
    Dana
    If an update failed after uninstalling the old version, that would explain it (there was an NVIDIA bug that caused this a while back, if your NVIDIA drivers aren't up to date), but DIM doesn't auto-update -- you would have had to launch it first.
  • XyetztXyetzt Posts: 27,554
    I want to go to bed, but it is only seven pm. I am so tired.
  • ps1borgps1borg Posts: 12,776
    Morning. Holiday today yay :) Sunny warm not much wind perfect day for floating around on the bay :)
    tee hee
    like:
    Zero Wing on Sega consoles :)
    edited March 2014
    that nice ballroom texture is in the mm naos http://www.daz3d.com/march-madness-shop-all-sunday-BWWW33/affable-for-the-ballroom
    didya ever take something off your w/l, change your mind about it, and then can't find it again?
    exaspers
    i was torn between liquid sky and this other brownish uniformy scifi outfit
    found it. doh, fell off the sale. haz really nice boots. overly bewbie hugger though.
  • starionwolfstarionwolf Posts: 3,670
    edited March 2014
    Thanks.
    Hi Misty Whisky, if you know the model number of your Asus computer, then I can look up the details some how. If you don't then we can try something else. I couldn't find a program that shows the version number of an unused PCIe 16 slot. Sorry.
    The Luxrender forums say that an Nvidia Geforec GTX560 is the minimum video card to use hybrid/openCL mode.
    edited for clarity
    Post edited by starionwolf on
    I don't think it will support any type on integrated graphics
    Misty Whisky wants to buy a new video card for her computer. She wants to find out what version of PCI express 16 slot she has. Hopefully she doesn't one of those all-in-one PCs with no expansion slots.
    But yes, openCL won't run on Intel graphics like the HD4000. I tried it.
    Probably gonna have to crack open the case and look on the motherboard for the model
    maxed out my flashdrive, making 3 trips between netbook and main rig. it's taking me all day to port my new runtime stuff.
    i haven't even installed the cararra upgrade yet. is it going to see my ds runtime, with all the genesis stuff?
    edited March 2014
    aah, you're right. Maybe she can download and run CPUz.
    You can see the motherboard chipset information in the tab called "mainboard".
    edit: I forgot to mention that the download links are on the right side of the webpage. You can either download the version that has a setup program, or a version in a zip file that you can manually unzip.
    Good luck with Carrara Misty Whisky.
    407 x 407 - 60K
    how can i see if my m/b has a pci express 2.0 slot?
    looking at buying this card http://www.amazon.com/EVGA-GeForce-Express-Graphics-01G-P3-1302-LR/dp/B0049MPQA4
    it has the cuda, and then i should be able to use the Octane.
    lux takes wayy toooo long to render. :?
    8 cores won't give you much of a speed bump, is a generation behind the 500's and looks like Rev 1 where I think the Rev 2 is low power consumption :)
  • JaderailJaderail Posts: 0
    Good luck with Carrara Misty Whisky.That is a COOL little App. TY for the link.
    files are still copying to my flash. this should be the last shuttle :lol:
    thinking up render ideas - lessee something like :) the bounty hunter & and the smuggler who dumped his cargo.
    no wine or sake tnite, makin chocolate milk with the hershey syrup. slurrrrrpp
    hmm well, netbook isn't too impressive.
    a while to go before i can render new stuff
    sleepy ... zonks zzzzzz
    45 x 30 - 7K
    395 x 169 - 24K
    383 x 467 - 90K
  • DanaTADanaTA Posts: 13,412
    Complaint: The torture of reinstalling things after having Windows 7 Pro installed. Can't find things that should be there (old stuff on old C: drive). Profiles and stuff missing. Lost all my Firefox bookmarks! I just can't find them. That is a great hardship, I had a lot of stuff bookmarked. :down: Spending hours and hours looking for stuff, copying it, no love, looking some more.
    Plus I can't boot from the old XP system (on a different drive - I got an SSD for Win 7). I get all kinds of errors, the system reboots and goes into the XP screen that offers the choice of safe mode, safe mode with network, etc. Neither of those two helped, it just rebooted, after showing all these errors. :down:
    Silly time of morning already and I haven't watched the news. Maybe I'll skip it. No, I need to unwind, anyway.
    Dana
    edited March 2014
    Is warmer at sunset than it was at noon today
    218 x 172 - 17K
    Post edited by ps1borg on
    The powers that be frowned on me. My nice weather will be interrupted with yet one more below Freezing day this very week. They changed the low by a total of 9 degrees over night.
    ...my own hard wired connection.
    Moon is out there in the night sky somewhere but cant see it through some low black harbinger clouds, a mess of seagulls flew over before heading inland, is real humid and sweaty like a tropical storm but without the wind and rain, spooky.
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,593
    had sudden flash shower of rain here and now it is gone.
    wondering what has happened to plane from Malaysia Airlines, crashed most certainly but hope not from human intervention.
