stockings product leaves annoying border around the legs
AristocAristoc Posts: 254
Morphing Pantyhose for Genesis 2 Female
When rendered there is sometimes a black line around the whole leg visible or sometimes an obvious gap
Is there a fix?
Thank u
  • SimonJMSimonJM Posts: 6,102
    That is probably down to the stocking, in this case, not snugly conforming to the contors of the underlying figure. You might get a better fit if you diald down scale a little (even to having the stockings disappear inside he figure a little) and turn on/up collision detection. Some areas, such as the heel are notorious for this sort of thing,
  • AristocAristoc Posts: 254
    will work on it. thanks.
