Adding to Cart…
Thanks again for maintaining this thread, Kerya. You rock. :)
Poser dynamic hair
NanetteTredoux
Low bun hair for V4
http://www.sharecg.com/v/74886/browse/11/Poser/Low-bun-hair-for-V4
Sustertjie hair for Pre-school Vicky
http://www.sharecg.com/v/74891/browse/11/Poser/Sustertjie-hair-for-Pre-school-Vicky
(for generation 2 Preschool Girl, not Maddie)
Refits
3dream
MSC - Sadie
http://www.sharecg.com/v/74888/browse/11/Poser/MSC-Sadie
MSC - Sam
http://www.sharecg.com/v/74889/browse/11/Poser/MSC-Sam
Thanks for helping! :)
Added to the main list ...
Just an info: I am not adding a message each time a second link shows up at Rero or Sharecg - in that case I simply edit the main list and add it.
Poser Dynamic Hair
PhilC
Dawn Short Curly Hair
http://www.sharecg.com/v/74939
Poser Dynamic Hair
Nanette
Marcel hair V4
http://www.sharecg.com/v/74948
http://www.renderosity.com/mod/freestuff/details.php?item_id=73505
PhilC
Dawn Long Dynamic Hair
http://www.sharecg.com/v/74947
I wanted to mention, there is actually 6 free hairs on this linked page, that is listed on post #1 as:
Akatora’s Twin Tails for Decoco
http://members3.jcom.home.ne.jp/mowais/freestuff/freestuff.html
Also, there is:
(2) Alice Hair (within the Alice Set)
(3) Deco Hair (within Decover3.zip)
(4) Maybe Hair (within Maybe1.02.zip)
(5) Heta Hair (within Decoco1.02.zip)
(6) Akatora's Twin Tails 2 (this is linked direct, the original Twin Tails in within Decoco1.02.zip)
I have not used them, but they appear to all be real nice, and I will be testing them out soon :)
I did not see them on the posting elsewhere?
(Note the pink one is twin tails 2, yellow is Deco, grey is Maybe and Alice is pretty obvious...Heta and TwinTails original are pictured seperately)
Thank you! First post of the thread is updated!
Poser Dynamic Hair
Rehder
PokeyHair Scampixie Pranx
http://www.renderosity.com/mod/freestuff/details.php?item_id=73522
Hair Painting Tutorial
RNKarenER & MysticFantasies Hair Painting
http://mysticfantasies.com/HairPainting.htm
Hi Kerya, I found Miku Hair in Miku wear set here: http://casiopea.jp/download.htm
Thank you! Added!
New too
Poser Dynamic Hair
NanetteTredoux'
Tresses Laura
http://www.sharecg.com/v/75059
DazStudio format
Sedartonfokcaj
Dante hair Genesis
http://sedartonfokcaj.deviantart.com/art/Dante-Hair-for-Genesis-435979176
That Dante Hair could be useful.
Also:
http://sedartonfokcaj.deviantart.com/art/Tina-Armstrong-s-Hair-for-Genesis-2-Female-434547551
http://sedartonfokcaj.deviantart.com/art/Mila-Hair-for-Genesis-2-Female-435769833
Niiice!
Thank you!
By the way: if somebody finds broken links - I would be grateful if you posted them so I can update the lists ... (as somebody mentioned in another thread that there are a lot of broken links ...)
Warning - the Sedartonfokcaj's hairs were made on a Mac and some folders are encrypted.
The zips didn't unzip correctly and I did have a hard time to get rid of the folders (folder names green - encrypted) and had to use the DOS console to rename folders to something Windows can read and then delete them ...
Sorry to hear that Kerya. I download the Mila hair and it loaded into a scene ok, but after reading your posting, I tried to use it. I could not parent it to the head and even if I tried to rotate it, it stayed in a static pose. I didn't get any green folders though and had no warning when I extracted using Winrar. Strange as it's the first item I've come across that behaves like this.
DYNAMIC HAIR
NanetteTredoux
Tresses for Laura
https://market.renderosity.com/mod/freestuff/details.php?item_id=73561 OR http://www.sharecg.com/v/75059/view/11/Poser/Tresses-for-Laura
HAIR FITS
3Dream
MSC - Genesis 2 Base Female
https://market.renderosity.com/mod/freestuff/details.php?item_id=73578 OR http://www.sharecg.com/v/75086/browse/11/Poser/MSC-Genesis-2-Base-Female
EDIT:
MSC - Genesis 2 Base Male
http://www.sharecg.com/v/75087/browse/11/Poser/MSC-Genesis-2-Base-Male
MSC - Dennis
http://www.sharecg.com/v/75092/browse/11/Poser/MSC-Dennis
For Sedartonfokcaj’s hairs (and probably all the other stuff, too).
I found at least one spelling error with the folders in the zip. The Dante hair has an extra space in "Genesis" (People > Genesis > Hair), so it won't merge properly. The others, I unzipped to a 'dummy' folder and manually put the individual folders where they belonged.
I'm on a Linux system and used the native KDE file archiver to extract them, so it's likely that something other than Windows native will have better luck in actually extracting them properly. Try 7zip (www.7-zip.org).
Mila hair...autofitted to Genesis 1...(now, someone needs to do up some textures for these...this one is darn cute, at least on this character)
I used the Dante hair last night and other then one of the folders having Genesis_ and and empty folder so I deleted the empty one and removed the _ and it worked fine.
I think you can avoid most of the problems by extracting and moving just the item folders into the respective content folders. The content folder structure in the zips is somewhat 'iffy'.
Is there anything for Aiko 3's Jordan hair?
Robkelk: added! Thanks!
FaerylWomyn: may I ask what you used to unzip?
I tried first with ExtractNow, which usuall does a really good job and then with the Windows7 native unzipper ...
I used 7zip, opens pretty much everything. One of the files or maybe more then one, is going to create a pop up window stating a bunch of things failed to open, that's because it doesn't like Mac files, but the pc files are just fine. Oh and 7zip is free.
http://www.7-zip.org/
Thank you!
Maybe Windows opened just too many files - the Mac files too - and that led to problems.
When I have a bit of time I will try again.
Time - just in case I can't get rid of folders again ;)
For free?
(checks the A3 freebies list)
No, nothing I'm aware of.
Sedartonfokcaj (Warning: made on a Mac and some folders are encrypted)
Converstion of Jackie Bryant's Hair
http://sedartonfokcaj.deviantart.com/art/Converstion-of-Jackie-Bryant-s-Hair-439703082
Jackie Bryant Hair Genesis
http://sedartonfokcaj.deviantart.com/art/Jackie-Bryant-Hair-for-Genesis-439704934
niseisya
Nearme Ponytail (click on Read More to see the link)
http://www.pixiv.net/member_illust.php?mode=medium&illust_id=42399642
DollyGirl
Cinco de Mayo Addon for redviper's mghmh
http://www.sharecg.com/v/75394
sassanik
Mostly Universal Hair Shader - Bright Colors
http://www.sharecg.com/v/75399
Mostly Universal Hair Shader Gradiant Colors
http://www.sharecg.com/v/75400
Mostly Universal Hair Shader - Stripes
http://www.sharecg.com/v/75401
Tutorial for Mostly Universal Hair Shader
http://bouncingdog.blogspot.de/2014/03/mostly-universal-hair-shader-tutorial.html
Garibaldi hair
CMK24601 Wolverine Hair Genesis
http://www.sharecg.com/v/75622
