UltraScenery [Commercial]
1…2223252728…100
  • Richard HaseltineRichard Haseltine Posts: 111,725
    L'Adair said:
    Hello! I apologize if this is a known issue discussed earlier in the thread, but I keep running into it and then forgetting to ask. I used to be able to load a couple of the landscape types, but after installing the expansion I get a script error every time and nothing loads. I've attached the log file from my past few attempts.
    I see several references to C:/Users/[Username]/Documents/DAZ 3D/Studio/My Daz Connect Library/data/cloud/1_67835/environments/landscapes/ultrascenery/ultrascenecreator.dse in the txt file. Did you install UltraScenery using Daz Connect?
    There are known issues with scripts and Daz Connect. If you used Daz Connect to install either UltraScenery product, I recommend you uninstall with Daz Connect first, and then reinstall with DIM. (Or install manually.) You will run into more issues if you don't uninstall whichever script was installed with Daz Connect before installing with DIM.
    It isn't that there are issues with scripts and connect, it's that there are methds of file handling that work with Conect and others that don't - it's also true that testing Connect-safety in advance is an issue, as far as I can see.
  • JOdelJOdel Posts: 6,322
    Just reporting that whatever was going on with the manual download for the update seems now to be fixed.
  • HowieFarkesHowieFarkes Posts: 630
    Oh weird, I didn't even notice that. o.Oa I usually use DIM exclusively.
    I reinstalled using the process you suggested, but unfortunately I'm still getting the same error.
    If you uninstalled via Connect and then reinstalled via DIM, and you're still getting those errors, it's time to call in the big guns. I'm one byte above clueless when it comes to Daz scripts, so maybe we can get @HowieFarkes's attention. He'll probably have the answers you need.
    Ha - I'm no expert on installation issues. All I know is that if things are in the correct directory relative to the user's content library things will work. Using Daz Connect and Smart Content can sometimes work and can sometimes not work - and why that is is not something I as a PA am equipped to trouble-shoot.
  • DoctorJellybeanDoctorJellybean Posts: 10,172
    Swan Lake
    1822 x 887 - 3M
  • plasma_ringplasma_ring Posts: 1,027
    Hi! I double checked the installation because it was suggested, but the log I attached says there's an error due to a specific line in the script. This seems to be the case no matter where I install it or what method I use.
    txt
    txt
    UltraScenery Log File.txt
    2K
  • barbultbarbult Posts: 27,608
    plasma_ring, did you select a feature? Someone else had a script failure because they skipped past the features and didn't select one.
    Aha, this seems to have been it, thank you very much! I'm not sure why I was skipping over that, but my brain has a lot of mysterious holes in it haha. That explains why it worked sometimes previously!
    I'm gonna have to go and put something in to fix that - disable the build button until a feature is selected or something.
  • fastbike1fastbike1 Posts: 4,084
    edited May 2020
    @DoctorJellybean
    That's really nice, and clever. I don't believe I remember those structures (???)
    Post edited by fastbike1 on
    fastbike1 said:
    @DoctorJellybean
    Thank you. The cottage is IN Fantasy RiverCottage over at Rendo, and the platform\roof is from Lakeside Folly and Rooftop Terrace.
    edited May 2020
    Or, just default to "No Feature" since that is a choice. Like the way it defaults to a basic terrain map.
    Post edited by barbult on
  • MelanieLMelanieL Posts: 7,878
    Swan Lake
    That's an interesting idea, I like it!
    I thought it did default to "No Feature"?!  (I'm amazed I've never managed to trigger that error myself.) Sounds like the best plan if it is possible to do it.
  • 3D-GHDesign3D-GHDesign Posts: 716
    edited May 2020
    First of all, that was an instabuy. I love this as I love all of your works!!!! I was so happy for the Harpwood one too, I already had the Harpwood. And can't wait for an Evergreen version maybe with some mountains around and the cherry on the top if we could get a more customizable feature with our own plants. Still we would love to get another exciting features and variations :)
    Post edited by 3D-GHDesign on
  • shadem980shadem980 Posts: 54
    HowieFarkes
    Hmm, just curious, but would it be possible to add an advanced control section for the features like road/river/path so there is a way to specify the width of them in the workable area. So for instance instead of a single lane, there is an option for a double lane or even more ambitious a crossroads with various options. I created the following, but it was through scaling up the Ultrascenery Group to 145% for a project I gave myself to do. Great Product and happy to be using it!
    4000 x 2472 - 4M
    I'm creating some ecologies using Andrey Pestryakov's awesome pine trees from Nature Trees Pack 4 so there will be an option for evergreen forests soon.
    795 x 1038 - 2M
    Thanks for the heads up on the upcoming ecology. Now we can shop for the required product and be ready when the UltraScenery addon arrives. It looks as great as all the previous ones.
    edited May 2020
    This is one of those crazy pictures that took on a life of its own. It started with Harpwood 2 and a fairly flat terrain with the intent of adding the Outpost in a clear area. Before I knew it I had UltraScatterPro scattering other plants and UltraTree putting an evergreen in the background to fill a gap. Then a Porta Potty jumped into my scene. How often can you find a use for that? What are flowers without butterflies, so I did a volume scatter with them. The Outpost was a little drab so I added some graffiti decals. There's a metal cup on the steps and a bicycle wheel amid the flowers. There's an old antenna on the roof, but it is barely visible if you know where to look.
    Edit: Oh, yes, I forgot. I added a dirt geoshell to the Porta Potty and an old piece of wood leaning against the Outpost. What else did I forget?
    2560 x 1440 - 2M
  • alexhcowleyalexhcowley Posts: 2,409
    Oaks, Pine trees and Tango Alpha's promised set. My credit card may never recover!
    Cheers,
    Alex.
    Treehuggers? Very nice and clever.
    Off the grid, for sure.
  • DaventakiDaventaki Posts: 1,624
    surprise Had wishlisted the trees for later but I think ill go ahead and get them now!  Thanks for the heads up!!
  • dawnbladedawnblade Posts: 1,723
    edited May 2020
    I just starting getting the "tree in the middle of the pond" issue that others mentioned earlier. Never happened to me. I have the latest DS and the latest update to this amazing product.
    I tried several ecologies including Harwood but still getting the same issue, default settings or not. I deleted the tree props that were outside the UltraScenery group, and DS crashed and burned once; other times it didn't crash, but not sure why this is suddenly happening to me.
    Oh, as an FYI, as of last week I installed the latest version of Octane for DS, but I don't have it open or have it set to automatically update. So this is not an Octane render.
    1920 x 1080 - 6M
    264 x 149 - 13K
    Post edited by dawnblade on
  • memcneil70memcneil70 Posts: 6,139
    The Still?
    Wonderful work @barbult.
    The Still?
    Darn! I wonder if I have one.
    Not something I can test - but I seem to recall that folks who even just had Octane installed (and not rendering with it) were still having problems with instances. The fact that it is on the system provokes the problem.
    Since Harpwood Trail comes with material presets, I applied the green preset to a couple of the tree objects that get instanced, to add some color variety. The woman on the chair is a billboard and blended in amazingly well for some quick foreground interest. I've become fond of using UltraScatterPro to add some additional plant variety (dandelions this time).
    I bought them today to. I'm ready for the next addon.
  • SevrinSevrin Posts: 6,314
    Am I mistake or do the Harpwood assets slow things down?  I went from a 1070 to a 2080ti and found that the former with the basic Ultrascenery was a lot less laggy than the latter with Harpwood assets.
    Ok, I disabled Octane, restarted DS, and ran USC, and no tree in the middle of the pond! yes
    Harpwood is much slower for me too.
