Viking Village- this thing needs a render thread
Lissa_xyzLissa_xyz Posts: 6,116
edited March 2014 in The Commons
I fell in love with this set, as I think quite a few people did. Wanted to start a thread to see what other people have been creating with it.
#1- DS4.6 + PhotoshopCS6 + NikTools (these flowers are somewhere near the back-left corner of the set)
#2- PP2014 + Terradome + Snarlygribbly's Free SnowMachine2 + PhotoshopCS6 + Ron's Winter Brushes + NikTools
#3- Just a normal PP2014 test render w/ Terradome + Aquazone
Post edited by Lissa_xyz on
  • TrishTrish Posts: 2,625
    edited March 2014
    Faveral...... Great Village just threw it in Bryce.. just to see what it would do....I need to add more lights but it...looks wonderful!!l....Thanks Trish
    1754 x 875 - 1M
    Post edited by Trish on
  • JabbaJabba Posts: 1,466
    A Reality/Luxrender test render that I'd left cooking overnight...
    1920 x 1080 - 2M
  • fixmypcmikefixmypcmike Posts: 19,742
    Has anyone gotten a good render from the opposite viewpoint, as if you were looking down from the mountains toward the village on the shore?
    Mine lost it's colour
    1200 x 675 - 291K
    Nice renders!
    Bullit has one in the member's section over here: http://www.daz3d.com/forums/discussion/37993/
  • FSMCDesignsFSMCDesigns Posts: 12,859
    That looks fantastic, what background did you use for reality?
    I love the look of this set, but I can't justify the purchase since I would only have a few uses for it
  • Miss BMiss B Posts: 3,071
    Fabulous renders everyone. Cho, I happen to like the black and white effect. Nicely done all.
  • sfaa69sfaa69 Posts: 353
    Please, please, give information about which program you are using and what lighting set up. There are those of us who need to learn.
  • CybersoxCybersox Posts: 10,038
    Just messing around with the set and lights and I suddenly remembered the old Disney film "Island At The Top of the World" with the all the fabulous Peter Ellenshaw matte shots of the viking city...
    2000 x 1414 - 915K
    I love the look of this set, but I can't justify the purchase since I would only have a few uses for itIt's the skydome that comes with the set, I just converted it to a Reality light and added a sunlight too.
    A fuller description on my dA page... http://fav.me/d78v5e9
    Interesting. Anyone know how that description would convert to Luxus instructions? I didn't realise it was possible to convert a skydome directly into a LuxRender environment light.
    O yeah, I've done it quite often on scene-specific skydomes & skyboxes. The easiest way in Luxus is to have your parameters tab active instead of the surfaces tab - click on the wee square to bring the dropdown (where you'd normally select to add Luxus Luxrender material) and you'll see the Luxus option is actually Luxus Luxrender Light.
    Also, I'd strongly recommend having the "Use LuxRender GUI" setting switched to "on" in the Luxus render settings - it's essential to be able to adjust light intensities on-the-fly while rendering so that everything isn't bleached to death.
  • fictionalbookshelffictionalbookshelf Posts: 837
    Here is a render I did of the church using a mix of lights that tinkered with.
    1500 x 1500 - 8M
    I know about that, it's how I set up an environment light with an .hdr file applied to a D|S Distant light converted to a LuxRender Infinite light. So which light type should I use to convert a skydome or skybox? I've tried everything obvious, and none of the settings appear to have a parameter slot where I can plug in something that isn't an .hdr image.
    Greetings,
    Just for fun, something I'm working on...
    -- Morgan
    724 x 543 - 320K
    edited March 2014
    A further progression of my previous image. The Let It Snow Shader is one of those one-trick ponies I rarely have an opportunity to use, but when I do find a use for it, it always delivers. Can't decide if the tiny added viking figure helps or detracts...
    2000 x 1125 - 817K
    Post edited by Cybersox on
  • IvyIvy Posts: 7,165
    edited March 2014
    The Stories that are told around a viking fire... :)
    The return of the hero's ~ Best Viewed Full Size 1920 x 1080 225 KB each
    A Re-post from another thread.
    1920 x 1080 - 217K
    1920 x 1080 - 280K
    1920 x 1080 - 196K
    1920 x 1080 - 184K
    1920 x 1080 - 181K
    Post edited by Ivy on
    The kiss
    1920 x 1080 - 299K
    1920 x 1080 - 262K
    1920 x 1080 - 225K
    1920 x 1080 - 232K
    1920 x 1080 - 255K
    I know about that, it's how I set up an environment light with an .hdr file applied to a D|S Distant light converted to a LuxRender Infinite light. So which light type should I use to convert a skydome or skybox? I've tried everything obvious, and none of the settings appear to have a parameter slot where I can plug in something that isn't an .hdr image.Sorry, I don't usually use Luxus and assumed all options were covered with the paramater light option.
    I had a quick look, and you set up as a light from the surfaces tab option instead of the "normal" light options in the parameters tab. So the steps would be to select skydome/skybox & with surfaces tab active:
    * Select the "Luxus - LuxRender Material" options from the dropdown menu (this can probably be narrowed down a bit but I didn't spend time exploring it).
    * Leave "Material Type" at the default "All With Switcher".
    * Check the "Light Parameters" and "Copy Studio Parameters" boxes, and click to accept.
    * In the Luxrender "Light" settings, make sure Luxrender Light is enabled (set to "on") and import the skydome texture into the "light color" setting.
    That's it really... it won't be near as good as a proper HDR image, but it'll give you a good ambient light source that contextually matches the visual environment, and you'll almost certainly need to add additional Luxus light(s)s to the scene so that focal point doesn't look too lacklustre (the details of the skydome will bleach out pretty quick if you try to boost the light intensity too much).
  • scorpioscorpio Posts: 8,534
    DS render.
    1500 x 903 - 439K
    edited March 2014
    And the Saga Continues
    Best viewed full sized 1029 x1080 - 229 KB each
    1920 x 1080 - 244K
    1920 x 1080 - 262K
    1920 x 1080 - 225K
    1920 x 1080 - 212K
    1920 x 1080 - 269K
    To Be continued
    1920 x 1080 - 252K
