Daz problems.... please help... getting very tired
Can you help?
I have googled all day and I am at the end of my tether. I have the PostgreSQL warning everytime I start the app. The various menus are blank. There seems to be dozens of suggestions scattered around the whole of the internet.
But the 'solution' I want to try now is to uninstall Daz. However, I cannot even do that because it doesnt exist in my uninstall options.
The help I require is...... what is the FINAL solution to the postgresql problem. Or what is the FINAL solution to unistalling DAZ.
I hope you can help
What OS?
How did you install DS (DIM or standalone installer)?
If you still want to uninstall and you're running Windows:
From your Start Menu, search for Add or Remove Programs
Find Daz, select Uninstall.
Sorry if you have already tried this.
Have you tried reinstalling Daz by downloading the installer from the web site (instead of using DIM)? This probably won't fix your SQL issue, but should create the uninstall option (if the installer itself doesn't pop up an option to uninstall, that is)
