Error from DIM I haven't seen before. (solved)
MarcCCTxMarcCCTx Posts: 943
edited May 2020 in The Commons
Trying to install update to UltraScenery
"This file could not be opened for reading. The package cannot be installed."
And I get this error, I'm thinking bad download, so I throw it away and redownload and get the same error. Problem on my ond of DAZ's?
Here's a picture of the error box...
Post edited by MarcCCTx on
  • Charlie JudgeCharlie Judge Posts: 13,301
    Same here.
  • duckbombduckbomb Posts: 585
    Same here.  Preceding this was some MS Framework install prompt that I approved but then THAT failed, as well.  Weird.
  • NorthOf45NorthOf45 Posts: 5,713
    I've seen that with corrupted downloads. If you right-click and select "Show Package Files..." is there a list of files in the popup dialog, or is it just empty? Mine went through okay a couple of days ago.
  • MarcCCTxMarcCCTx Posts: 943
    edited April 2020
    OK I see in the UltraScenery thread others are having the same problem as well, so it's not just me. And the old one still seams to be working.
    Downloaded the file manually, but it is corrupt. Truncated, actually, missing several files and folders, updated or not.
    A good version showed up.
