Error from DIM I haven't seen before. (solved)
MarcCCTx
Trying to install update to UltraScenery
"This file could not be opened for reading. The package cannot be installed."
And I get this error, I'm thinking bad download, so I throw it away and redownload and get the same error. Problem on my ond of DAZ's?
Here's a picture of the error box...
946 x 569 - 38K
Post edited by MarcCCTx on
Same here.
Same here. Preceding this was some MS Framework install prompt that I approved but then THAT failed, as well. Weird.
I've seen that with corrupted downloads. If you right-click and select "Show Package Files..." is there a list of files in the popup dialog, or is it just empty? Mine went through okay a couple of days ago.
OK I see in the UltraScenery thread others are having the same problem as well, so it's not just me. And the old one still seams to be working.
Downloaded the file manually, but it is corrupt. Truncated, actually, missing several files and folders, updated or not.
A good version showed up.
