my tyres won't turn
wheel parts are all parented to the pivot, is just weird
    change rotations to angles  ?
    by default rotation, they won't rotate 360
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,456
    I can manually rotate them separately and I am using a spin modifier on the group so they do
    your tyres do turn?
    i'm confused
    edited April 2020
    Mystiarra said:
    your tyres do turn?
    i'm confused
    they won't turn with the rest of the stuff under the pivot with the spin modifier
    you need to watch the video to see what I mean cheeky
    I tried different constraints
  • DiomedeDiomede Posts: 15,401
    Mystiarra said:
    your tyres do turn?
    i'm confused
    strange - can you try with a target helper as an intermediate object?  I vaguely recall having something like this happen to me quite a while back - don't remember the solution.
    edited April 2020
    Diomede said:
    Mystiarra said:
    your tyres do turn?
    i'm confused
    I am guessing it is something with the FBX import
    it was 3ds but I changed it to FBX in iClone 3DXchange as Carrara 3ds import is rather crappy
    while it's a prop maybe it acquired some rigging?
    no luck, tried groupimg
    removing from tree, parenting to a target helper, angles as well as quarternium
    can manually rotate it with arrows but it just won't move on a modifier
