my tyres won't turn
WendyLuvsCatz
WendyLuvsCatz
change rotations to angles ?
by default rotation, they won't rotate 360
I can manually rotate them separately and I am using a spin modifier on the group so they do
your tyres do turn?
i'm confused
they won't turn with the rest of the stuff under the pivot with the spin modifier
you need to watch the video to see what I mean
I tried different constraints
strange - can you try with a target helper as an intermediate object? I vaguely recall having something like this happen to me quite a while back - don't remember the solution.
I am guessing it is something with the FBX import
it was 3ds but I changed it to FBX in iClone 3DXchange as Carrara 3ds import is rather crappy
while it's a prop maybe it acquired some rigging?
no luck, tried groupimg
removing from tree, parenting to a target helper, angles as well as quarternium
can manually rotate it with arrows but it just won't move on a modifier
