Daz freezes for 5 or 6 minutes
Hello Guys. I would appreciate it if you could guide me. When dragging the keyframes in the timeline, or posing using puppeteer, the software hangs for 5 or 6 minutes! I wanted to know if this would solve the problem if I do upgrade my processor (although not all the CPU power is currently being used) (attached pic) or if this problem is due to the Daz software itself and by upgrading the processor it wont be solved!
My CPU is 6core Ryzen 5 2600, I have 16 GB ram 3200 MHZ
Thanks in advanced.
I think the main problem is a lot of things are still run on one core, so our nice multicore ryzens are being severely under utilized
I'd suggest turning off all the smoothing modifiers used in the scene.
I've found those to be the biggest culprits of DS hangs like this.
Thank you. How do I determine if it uses all 6 cores?
Actually smoothing modifier is off, but still there is this problem.
