Unassigned Category disappeared and Content Libray alphabetizing lag
ChromaDrakeChromaDrake Posts: 288
DAZ 4.6 is not longer showing the Unassigned category anymore when I install new content by the Daz Install Manager or when I simply copy Renderosity files into My Library. Is there any advice on what I can do?
There is also a weird lag in my Content Library. If I change a category/folder name, it does not alphabetize the new name unless I move a folder into another folder or sometimes if I go to another library category (only sometimes). When I move another folder into another folder suddenly every new folder name that was changed is alphabetized.
According to Task Manager, Content Management Service is running.
Post edited by ChromaDrake on
  • fixmypcmikefixmypcmike Posts: 19,733
    Are they not showing in Unassigned after doing "Scan Known Directories for Content"? That sounds like a corrupt database.
    1) If you haven't exported user data recently, do that first, so you can restore the categories that are still working.
    2) Close DS and uninstall CMS.
    3) Reinstall CMS by running the installer in C:\Program Files (x86)\DAZ 3D\DAZ3DIM1\cms (if you have DIM installed) or by reinstalling DS. That will give you the latest CMS, which will reduce the chances of the problem recurring.
    4) Search for the file ContentDB.ind -- if you let CMS install to the default locations it will probably be in Program Files (x86) or ProgramData. I would search your entire hard drive with "Hidden and System Files" visible, in case you have more than one set of databases, which could also cause problems. That file is the index for the database.
    5) Stop CMS and delete ContentDB.ind, then start CMS and launch DS. Let DS rebuild the index -- it might take a minute or two.
    6) Scan for new content and categorize it.
    7) Close and restart DS, and see if the categorized items are staying. If they are, you should be good to go.
    8) If newly-categorized items are still disappearing, close DS, stop CMS, and delete all the files in the databases folder. Restart CMS, launch DS, and re-import metadata to get your user data back. It can take a long time, so don't panic if it seems to be taking a long time and the progress bar isn't moving.
  • ChromaDrakeChromaDrake Posts: 288
    edited March 2014
    I'm having problems with step 3. There was no 'cms' file in the specified folder.
    I went ahead and uninstalled and reinstalled DS using DIM and still no sign of any 'cms' folder or program. I did a search of the whole C: drive.
