Micheal 6 bundle broblem in daz studio!
bapshatbapshat Posts: 0
HI
i have daz studio ver 4.0.2 and i donloaded micheal 6 pro bundle and installed with daz download maneger
butt when lounch daz nothing comes in smart content any one can help me
    You are using an extremely old version of DAZ Studio. We are now using 4.6.2.118 as the general release version. Is there a particular reason for this.
    Do you have Genesis 2 Essentials installed? It may not install in DS 4.0 either, but it is required to use Michael 6, as he is a morph of Genesis 2 male.
  • BeeMKayBeeMKay Posts: 7,019
    Does the figure show up in your content library under
    DAZ Studio Formats -> My DAZ3D Library -> People -> Genesis 2 Male -> Charaters ?
  • bapshatbapshat Posts: 0
    edited March 2014
    tnx for feedback .i also have --DAZ.Studio.Pro.4.6.0.18.x64-- and test not work
    butt i not installed Genesis 2 Essentials
    where find Genesis 2 Essentials?
    Genesis 2 Essentials is Genesis Starter Essentials ?
    Post edited by bapshat on
    Ther are 2 sets of starter essentials, Genesis Starter essentials and Genesis 2 starter essentials.
    701 x 469 - 173K
    edited March 2014
    If i install Genesis 2 starter essentials i can use vicktoria 6 and micheal 6 in 4.0 or 4.6?
    i cant find genesis 2 starter essentials anywhere?
    link?
    Go to "My Account", then select "Product Library".
    Then, select the DAZ Studio 4.6. As the image by chohole shows, there you will find the links to the Genesis and Genesis 2 Essential bundles.
    You can find the download links for manual download there.
    TNX BRO
  • JaderailJaderail Posts: 0
    Umm folks which was the lowest version that could read DUF? I'm not sure that version of DS can load the duf content even if installed.
  • Richard HaseltineRichard Haseltine Posts: 111,279
    Yes, .duf requires DS 4.5+
    edited March 2014
    it steel not working i have DS4.6 and i downloaded G2 StarterEssentials and installed with DIM butt when i load micheal it showw an error
    752 x 457 - 70K
    In DS, Edit > Preferences > Content Library > Content Directory Manager, expand the "DAZ Studio Formats" and "Poser Formats". Make sure you have "C:\Users\Public\Documents\My DAZ 3D Library" listed under both.
    I see you have Genesis in the Scene? The poses for M6 will NOT apply to Genesis, you MUST load M6 first The file you need to load, is 'Michael 6.DUF' and it should say 'Actor' in the label at the top right of the icon.
    You can load Genesis 2 Male first, then select it in the Scene pane, and then in Smart Content, M6 will appear.
    NO ITS C:\Users\kh-d\Documents\DAZ 3D
    edited March 2014
    DIM installs to C:\Users\Public\Documents\My DAZ 3D Library (the path that Mike gave you). Did you change it?
    If you have your library in another folder, you need to get DIM to install there. Inside DIM, go to the little Gear icon at the top right of the interface, and you can add another library path there for installing to.
    If you don't want to do that, then just tell DS where the DIM content is installed to, by adding the default path to the Content Directory Manager.
    Post edited by JimmyC_2009 on
