Riot Girl hair fix?
ValKyrie_1856200ValKyrie_1856200 Posts: 133
edited April 2020 in Daz Studio Discussion
Is there a way to fix this hair to make it fall more realistically? Normally I would just switch it up with another product, but this was designed to conform to the hat, and I haven't had any luck flattening any of the other hair products I own enough no mattter how much I play with sliders. Note the sharp angles to the hair in various places.
Post edited by ValKyrie_1856200 on
  • NorthOf45NorthOf45 Posts: 5,707
    Try adding subdivision on the hair. That will at least reduce, if not completely remove, any visible sharp angles. I don't see any movement morphs anywhere, though.
  • Thanks for the suggestion. Would there need to be movement morphs to add subdivisions? Sorry, I have yet play with any of those features in DS yet. :)
    No, subdivision works with the mesh, but does not depend on morphs. Morphs physically move the vertices and adding subdivision allows for more interpolation points to help keep the surfaces smooth and/or add detail (like for HD morphs). Sounds contradictory, but you need the higher resolution to add those intermediate points.
    In case you haven't found how to add subdivision, select the hair in the scene, the from the menu select Edit -> Figure -> Geometry -> Convert to SubD. In the parameters tab, General -> Mesh Resolution to adjust various parameters. View SubD Level is for the viewport, Render SubD is for the final product.
  • ValKyrie_1856200ValKyrie_1856200 Posts: 133
    edited April 2020
    OMG, that's like magic. What a difference. Thank you so much!!
    670 x 794 - 315K
