Clothing Tile Setting?
Hi, I know I've ask this before but I've slept since then and the dog ate the forum posting and my notes. :)
I added made a jpg for a pants and added them in the surface area just like I have done but the jpg is someone as a tile. How do I turn off tiles?
Thanks
Kimberly
Set Tiles to 1 and 1 that's all I do.
Also, make sure that it is really tiling that is at fault. This sort of a thing could be created by having multiple material zones on the pants with the same texture applied to each.
Where do I find the tiles setting to set them. I looked for tile setting be I posted and can't find them.
Thanks
There are four zones. Pants front and back and belt front and back. But I'll check on that. Thanks
If the texture you applied is tiling it will list in the Mat Zones in some area here is one I just loaded set to 10. Are you sure you applied the Texture to EACH material? Like once to Front an Once to Back ect...
Okay are you 100% sure the texture is CUT so it ends at the EDGE of the pattern? Looking close it seems to have EXTRA space around the edges... I think.
Thanks, I had that set as 1 and 1, I thought you meant there was another place. The pattern is set correctly on the lines. There has to be something else going on here, I going to go back and look at the uv map.
