Asian skin works tattoos dont work!
I bought the Asian skin works tattoos and when i load it on a figure
they are so faded you hardly see them. See image
What am i doing wrong - I tried different lightsettings and as you
can see on my image its almost perfect light for the figure!
  • FenixPhoenixFenixPhoenix Posts: 3,213
    If these are LIE set on the diffuse channel, it may be that the translucency on your character is too high. Decreasing that should make the tattoos pop. Another way to go, would be to manually add the tattoo textures to the translucency maps, that way the tattoos will show regardless of the translucency settings.
  • My 3D SpinMy 3D Spin Posts: 611
                     So i should try with different Charachters to see what skin is best?
    You where right - They worked perfectly on other skins-Thank you!
    My pleasure :)
