How can I get the leaves to display in the Harpwood Trail Scene Preset?
Hi! I purchased Howie Farkes' Harpwood Trail and loaded the "Harpwood Trail Preset." The forest loads, sort of, but the trees have no leaves on them and the ground has no ferns or flowers. Does anyone know how to get these to display? Thanks!
--August
  • scorpioscorpio Posts: 8,533
    Have you tried rendering?
  • chris-2599934chris-2599934 Posts: 1,977
    Howie's stuff makes a lot of use of instancing - using the same 3D objects multiple times around the scene. There's a setting somewhere in the instanced object that determines whether they're visible in the viewport. Unless you have a very beefy PC it makes sense to set this to "off", as it makes the viewport very clunky to work with if Daz has to redraw hundreds of objects every time you move the camera.
    You should find everything shows up if you do a render.
  • Thanks! I appreciate the help!
