Model not importing with Duf scene - bones do
HeadwaxHeadwax Posts: 10,464
edited April 2020 in Carrara Discussion
Hya, just  playing with that well known Carrara Plugin in Daz Studio and saving out a duf = but when I bring it into Carrara only t he bones come in.
When I load up Victoria 4 in Studio I ghet an error (?) message flashed on the screen that I cant read (too fast) - but she loads up okay.
Previous to that I was advised I didnt have my poser runtime setup properly in Studio - so I added my Carrara runtime to Studio (where I have m4 V4 etc.
I have been using Stuido 4.5 but in an attempt to get carraar smart content to work I reinstalled Studi0 4.1.
Thanks for help. Same thing happens in Studio 4.5 and 4.1
EDIT It happens with all figures!
cheese
Post edited by Headwax on
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,614
    grab DS4.12 latest beta, it works fine with Carrara and you can have it as well as the release build
    yours is a tad early pre postegresql which is likely the issue
    Still keep it though as its great for duf exports of Optitex simulations esp if using a certain script
  • HeadwaxHeadwax Posts: 10,464
    ah thanks Wendy. I was confused about studio versions - assumed 4.5 was later than 4.12 ... der
    Yes I am using 4.12 - still no joy. I save a scene as a duf and all that comes in are the bones but no flesh - happens with v4 m4 fairy wings etc - havnt tried it with genesis
    I have studio searching for all my content now  , that shjould keep it busy for a year
  • Bunyip02Bunyip02 Posts: 9,292
    edited April 2020
    Do you always save as a scene ? Have you tried saving as a Scene Subset to see what it will do ? I normally save my DAZ Studio items as Scene Subsets.
    3840 x 1035 - 765K
    Post edited by Bunyip02 on
    thanks I'll give that a go!
    edited April 2020
    how are you loading V4 in DAZ studio
    Powerloader?
    if that's giving the error message it might be a missing morph package ticked
    are you ticking options or not
    are you using LOD?
    are you doing any conversions
    she is legacy so should be saved as is not converted to weighmapping
  • StezzaStezza Posts: 8,927
    edited April 2020
    Just wondering if you have two lots of Vicky installed and they are cross talking or something..
    I had a similar problem once so now just load Vicky from the ds structure... if that makes sense wink
    Post edited by Stezza on
    edited April 2020
    also the order you have your Poser runtimes added to DAZ studio makes a difference
    the main one with Vicky's !Geometry files and cr2 needs to be first or the deltas in other ones can cause conficts with Powerloader in particular
    as Stezza said using the Poser directory loading base figure no morph injections not only avoids this but makes a lighter file
    cross talk brings back memoriessmiley.  loading 2 sydneys in poser 7, both figures would follow the morph settings, couldnt have one skinny and one chuby
    thanks Bunyip02 for the suggestion. Still no joy!
    edited April 2020
    Powerloader?
    are you using LOD?
    Hya Wendy - yes powerloader comes up _ I am using LOD . It comes up with two unticked boxes saying no metdata found.
    One is Creature Creator morphs for V4 (ps_mr258)
    and other is No metadata found no metadata found (ps_mr658
    The base morphs and Morphs++ seem to be injecting.
    It's not just V4 though... &^%^%$%$&*&&^!
    it happens with all figures = eg V ictoria 2 Lo Res comes into Carrara without a body.- see pic - there is no model in the instances list
    1382 x 998 - 274K
    1382 x 998 - 259K
    2108 x 1406 - 804K
    Haha just did a search for v4 obj and yes she is installed in four places - but not in the latest drive that I got dim to download my entire product library ... not sure what is going on there.
    It was working fine before I downloaded my entire library - I changed the name of the file that DIM uses to see what it has downloaded so it would download everything.
    Maybe that's the clue?
    I'll try loading her up from the ds structure - but iyt is a problem with all figures - they load into studio okay but dont come into carrara via the duf file...
    2226 x 482 - 256K
    thanks for the idea Wendy - I have my Carrara directory at the top of the Poser runtimes - and that is where she is installed.
    I just loaded up Vick via her cr2 file in Studio and saved as duf but still no joy gahagggggggggggggggggggggggggggggaggggggggggggggggggggggggggggggggggggggggahhhhhhhhhhhhhhh!
    ah I missed the fun of cross talk :)
    edited April 2020
    And meant in DAZ studio preferences
    and if you have V4 installed 4x you are going to have issues in everything
    especially DAZ studio
    she has to have only one installation
    LOD will give issues in Carrara too
    Thanks Wendy,
    Just uninstalled Studio 4.12 vbia DIm and then unistalled Stuido 4.10 by deleting the directory as it had no unistaller...
    No reinstalling via DIM the lates Studio - see if that works?
    Not sure of how to get rid of three of the V4s?
    hmm well uninstalling and reinstalling didin't work...
    the issue is not with DAZ studio it is your runtime setup
    try only adding one to DAZ studio in preferences and see if it works
    edit some mechanical figures and genesis 2 come in fine ....
    when i had vicki in poser, i deleted all her magnets and saved as a new cr2.  made a big performance difference.
    was there something about smoothing and duf figures?  think Wendy mentioned somewhere turning off the smoothing for performance.  cant remember how tho
    thanks will check that out :)
    well this worked - luckily !
    quote from poser newsletter
    https://www.posersoftware.com/article/470/3-ways-poser-works-with-other-programs-plus-the-daz-workaround
    How to do it:
    • Load the figure in an empty scene in DAZ.
    • Apply any of the morphs you want to include. (Don't need to be actively applied just displayed in the list of morphs)
    • Choose File > Export > Poser CR2.
    • Select Base figure type.
    • Choose a runtime folder for Poser. (Pro tip: Put into in a new empty runtime so it's easily located.)
    • Check Save with PMD.
    • Check Collect Files in Base Runtime Path.
    This gives you a Basic CR2 for Genesis 1 or Genesis 2, but DAZ saves the files in Poser 9 format so there won't be materials for SuperFly.
    not sure if you could use this to reduce genesis sizes as well?
