Make dragon wings grow?
How can I give the dragons bigger wings? Is there a morph for bigger wings?
  • tj_1ca9500btj_1ca9500b Posts: 2,057
    You could try adjusting the X/Y/Z scaling of the various sections of the wing  under Parameters.  Once you achieve the desired size, I'd suggest locking the scaling so that pose presets don't mess with your wing size.
    Sometimes you can select the elements and sub-elements in the Scene tree/Parameters tab so that you can uniformly apply the scaling you want.
  • scorpioscorpio Posts: 8,533
    Which dragon?
    I'm pretty sure that the Daz dragon 3 has a morph that scales the wings.
  • cherpenbeckcherpenbeck Posts: 1,416
    This nice little Dragonling for Dragon3 - his wings are much too small.
  • SimonJMSimonJM Posts: 6,072
    Under Shaping theer should be, under Wings, a Wings size slider, as well as a Wings Span, also a DA Dragonling Wing Scale (smaller values makes bigger wings)
    Ah, okay, I might need to look a bit closer at all these sliders. (Recommend myself to use my glasses) Thanks!
  • xyer0xyer0 Posts: 6,353
    Three pinches of brimstone and a thimble of ground Unicorn horn nightly for a fortnight.
