Make dragon wings grow?
cherpenbeck
in The Commons
How can I give the dragons bigger wings? Is there a morph for bigger wings?
You could try adjusting the X/Y/Z scaling of the various sections of the wing under Parameters. Once you achieve the desired size, I'd suggest locking the scaling so that pose presets don't mess with your wing size.
Sometimes you can select the elements and sub-elements in the Scene tree/Parameters tab so that you can uniformly apply the scaling you want.
Which dragon?
I'm pretty sure that the Daz dragon 3 has a morph that scales the wings.
This nice little Dragonling for Dragon3 - his wings are much too small.
Under Shaping theer should be, under Wings, a Wings size slider, as well as a Wings Span, also a DA Dragonling Wing Scale (smaller values makes bigger wings)
Ah, okay, I might need to look a bit closer at all these sliders. (Recommend myself to use my glasses) Thanks!
Three pinches of brimstone and a thimble of ground Unicorn horn nightly for a fortnight.
