Adding to Cart…
FaceShifter for Genesis 8 Female: The Missing Morphs Update
The original FaceShifter posts have been updated with the new files, this contains the updated morphs only.
Copy files to your Daz library
Cheers,
Daniel
Download the update from your Gumroad library
Or, download at ShareCG:
https://sharecg.com/v/94800/browse/21/DAZ-Studio/FaceShifter-G8F-Missing-Morphs-Update
Also updated the .CSV file for easy morph export
https://sharecg.com/v/94802/browse/21/DAZ-Studio/FaceShifter-Morph-Export-.CSV
WOW ! Amazing ! I really like these faces.
Thank you so much for this very cool gift!
Merry Christmas !
Hi Thank you for face shapes. Espcially the csv export rules, which make the whole thing really doable. I have a question, is there some way to make the genesis neck and eyes node, bone, joint availble in the export so that they can be connected in Faceshift? thanks Jack
I don't know why I didn't include it previously, but I've updated the main post with a link to the video tutorial on installation and useage. It shows how to connect the joints in FaceShift:
Cheers,
Daniel
How do I rename the shaping dials? I use FaceShifter a lot to build expressions but the problem is that I have a ton of dials under Parameters. The dial names are too specific to use filter so I have to do a lot of scrolling. Not to mention I have to click the full path in All into Expressions every time I need to add a new FaceShfiter dial into the mix. It would be so much more convinent if all the FaceShifter dials have ITF prefix in front so I can just filter all the dials by ITF and swtich back and forth between Currrently Used and All. I tried renaming the files but I guess that's not how Daz3D works.
This mainly a problem because clicking a new expression in Content Library will zero out other FaceShifter dials, which makes Content Library not usable for mixing.
Thanks again for the awesome set.
Note to self: Drop a few bucks for the incredibly useful resource and add a link to it on whatever storefront these characters wind up on...
Yuki...
Rumiko, Amelia, and Nanami...
Nanami again, Emily, and Aleksandr...
and... Alyssa.
Every one of those has had their basic expressions adjusted with FaceShifter in some way... Indispensible.
