question on render settings
KeithHKeithH Posts: 338
Attached are my render settings.
When I render complicated scenes it ends before it is finished rendering and unsure how to change that.
What do you recommend changing in my render settings?
What can I change to allow me to render complex scenes without it stopping before it is done?
Thank you
  • MattymanxMattymanx Posts: 7,002
    edited April 2020
    The 3 primary options that will help make it render longer, for more samples and a cleaner image, are "Max Samples", "Max Time" and "Quality" (quality is divided into several parts).  Basically DS treats all 3 functions the same in that which ever comes first, max samples, time or quality, is where it stops.
    My personal settings:
    Max Sample: 50,000
    Max Time: 90,000
    Quality - On
    Render Quality: 3
    Rendering Convergence Ratio: 99%
    This basically gives Ds plenty of time to work the noise out.  Most of the time, 99% convergence is reached loooong before max time or samples is reached.
    Post edited by Mattymanx on
    If your render finishes before it's clear of artifacts you can go into render settings, increase the render time, and then resume the render from where it stopped. No need to start all over again.
  • KeithHKeithH Posts: 338
    Max Sample: 50,000
    Max Time: 90,000
    Quality - On
    Render Quality: 3
    Trying this now - Will post if it works Thanks
  • SevrinSevrin Posts: 6,314
    You gotta be careful when loading anything, like an HDRI with render settings or certain "Ready-to-Render" set products.  Sometimes they will set your Progressive Rendering settings back to 2 hours and 5000 samples, wasting your time with a crappy render.
    That is great advice - thank you
    It looks like changing the settings work now just takes forever to render LOL but it is rendering
    If your render still isn't looking as good as you want it despite what the convergence value says, one possibility is the scene lighting. This is one of the more difficult things to wrap your head around in the 3D business, and good (or bad) lighting can make or break a render.
