Victoria 6 Smart Content issue
RiggswolfeRiggswolfe Posts: 916
My smart content appears to be quite messed up, particularly with Victoria 6. Both poses and wardrobe are missing. I tried re-importing meta-data. I also tried copying the database elsewhere, restarting Daz and again, reimporting the meta-data.
Any other things I should try?
    How did you install V6, using DIM or manually?
    I just tried this in the latest version of DS, and, with V6 selected in the viewport, I get all the usual options Poses and Wardrobe included.
    I almost never use Smart Content and mine works, which doesn't help you, but it's just the nature of things :)
    Have you tried uninstalling and reinstalling V6. If you used DIM, it should be fairly painless and only takes a few moments?
  • RiggswolfeRiggswolfe Posts: 916
    I used the DIM. I didn't try uninstalling and reinstalling but honestly, I don't think the issue is with v6. I have to admit wondering if something that installed with Stephanie might not have caused the problem.
    I truly think that the issue might be my meta-data being corrupt. I've entirely removed and reloaded the database without that helping. Does anyone know how to have Daz discard the meta-data and rebuild it from scratch?
  • lcfarlcfar Posts: 88
    Try re-importing the Genesis 2 Female metadata. I noticed the same thing, but it was true for all the G2F females, not just V6. Re-importing the metadata fixed it for me. I think you may right about Stephanie 6 messing it up, it was okay before that.
    edited February 2014
    I reimported all of the meta-data and it didn't fix it. I guess I could run an import and just select Genesis 2 Female. Is that what you did? Just G2F? What about the v6 meta-data?
    Edit: I just tested and it happens to Olympia too so I suspect it is all g2f as you said.
    Post edited by Riggswolfe on
    That did it Icfar! I imported only the G2f metadata along with the sub-characters. All of them except Stephanie. They seem to be working now. Thank you!
