Iliac crest too prominent
Hi, that might be a stupid question, but I don't get it.
Why are all Genesis 8 figures so skinny compared to the same Genesis 3 figures?
My problem is that I can't eliminate or reduce the visibility of the iliac bone (iliac crest) which is too prominent and unreal.
  • FenixPhoenixFenixPhoenix Posts: 3,200
    Is the comparative screenshot sowing the base Genesis 8 and Genesis 3 figures? If so, I think you may have a bad morph in your G8M data altering your figures. Because that's not how the original base looks like.
  • bebez71bebez71 Posts: 4
    Hi, the image above is not the base but a same Genesis 3 and 8 figure.
    What I am attaching here instead is the Genesis 3/8 base.
    Can you post a comparative screenshot?
    Thanks
    1003 x 547 - 234K
    edited April 2020
    @bebez71, yeah it appears that you may have a body morph that's applying to all your figures. Check to see which character/morph pack you installed when the issue started. You can also select the character and then in the parameters tab, click on "currently used" to see if there's a morph being applied. If nothing shows up, click on the upper left corner (hamburger button) and then check "show hidden properties" to see if a corrective morph is being applied. I'm attaching what the G8 Female Base looks like.
    1060 x 848 - 488K
    Post edited by FenixPhoenix on
    Many thanks I'll try
    OK it worked, in the parameters I didn't see anything strange, so I tried to reset to "zero figure shape" and see what changed compared to the other figure. There were actually two morphs that were applied to the body and face, but I was unable to reset them even by setting them to zero via the gear wheel (when I recreated the figure they returned to being applied). I simply deleted them from the library.
    Thanks
    609 x 819 - 271K
    Glad you managed to fix the issue, @bebez71. If the offending morphs were from a paid product you can always sibmit a ticket so the PA can fix it/them.
