No longer able to select individual body parts.
I just started using daz recently, and normally, I could either click on, or select, specific body parts under Genesis 3 Female. Today I was messing around with different geometry things, and after clicking something in one of the create or edit tabs, (not sure which), I can only select body regions, and they glow with a yellow outline when I do. I am unable to translate or scale the parts individually, only the whole genesis model. I experienced a similar issue when exporting daz characters to blender, but now it is like this in daz. I have restarted the daz client multiple times, and this issue occurs over all of the figures I select. Does anyone know of a solution?
  • Richard HaseltineRichard Haseltine Posts: 111,234
    You probably have the Surface or region Select tool active - switch back to the Node Selection tool or one of the transform tools (Universal is the default, as I recall) from the Tools menu.
