[Released] Wyvern Master Pose Control [Commercial]
RiverSoft Art
Become the master of the awesome HH Wyvern! Designed exclusively for Herschel Hoffmeyer's Wyvern, Wyvern Master Pose Control gives you a set of pose control scripts for creating or enhancing poses for the HH Wyvern! To get you started, it includes 32 full poses and 34 partial poses for the Wyvern. Written specifically for the bone structure of Herschel Hoffmeyer's Wyvern, these pose scripts allow you to precisely target body parts of the Wyvern.
Make every pose a partial pose whenever you want! Easily mix and match Wyvern Poses using the Wyvern Master Lock Bones script. Leverage your prior purchases by converting Dragon 3 poses to the Wyvern bone structure using the Wyvern Master Convert Poses script, creating the perfect starting point for your new poses*. Use the Wyvern Master Randomize script to create new poses or enhance existing poses for selected body parts of your Wyvern.
By using knowledge of the Wyvern bone structure, precisely target which body parts to randomize a little for a hint of realistic imperfection or randomize a lot to create new poses. With just a couple of clicks and the Wyvern Master Tail Control, easily twist, turn, or curl the tail of your Wyvern. Easily create precise, sinuous, s-curves by applying the control twice, once from the base of the tail and once from the middle of the tail. Add a touch of randomization to give that real-life look to the posing. With the Wyvern Master Neck Control, you get the same precise control over the wyvern's neck without affecting the body or the head. Use the Wyvern Master Wing Control to cup, flap, and move wings forward and backward quickly and easily, plus perturbation for that lifelike look.
32 Full poses (16 poses and their mirrors) and 34 Tail poses (17 partial poses and their mirrors) are included with the package!
* Because the Dragon 3 rigging is so different from the Wyvern rigging, the converted poses should only be used as a starting point for your final poses and will require adjustments.
- Wyvern Master Pose Control
- Detailed Wyvern Master User Guide
- 6 Wyvern Master Pose Control Scripts:
- Wyvern Master Lock Bones
- Wyvern Master Convert Poses
- Wyvern Master Randomize
- Wyvern Master Tail Control
- Wyvern Master Neck Control
- Wyvern Master Wing Control
- 32 Full Poses:
- Wyvern Attacking 01 M
- Wyvern Attacking 02 M
- Wyvern Attacking 03 M
- Wyvern Cowering 01 M
- Wyvern Cowering 02 M
- Wyvern Flying 01 M
- Wyvern Flying 01
- Wyvern Flying 02 M
- Wyvern Flying 02
- Wyvern Flying 03 M
- Wyvern Flying 03
- Wyvern Inspecting 01 M
- Wyvern Landing 01 M
- Wyvern Landing 01
- Wyvern Lying Down 01 M
- Wyvern Perching 01 M
- Wyvern Perching 02 M
- Wyvern Stalking 01 M
- Wyvern Stalking 02 M
- Wyvern Standing 01 M
- 34 Tail Poses:
- Corkscrew Tail 01 M
- Corkscrew Tail 01
- Corkscrew Tail 02 M
- Corkscrew Tail 02
- Corkscrew Tail 03 M
- Corkscrew Tail 03
- Corkscrew Tail 04 M
- Corkscrew Tail 04
- Curl Left Tail 01
- Curl Left Tail 02
- Curl Right Tail 01
- Curl Right Tail 02
- Curl Under Tail 01 M
- Curl Under Tail 02 M
- Curl Under Tail 03 M
- Side to Side Tail 01 M
- Side to Side Tail 02 M
- Side to Side Tail 03 M
- Sinuous Tail 01 M
- Sinuous Tail 01
- Sinuous Tail 02 M
- Sinuous Tail 02
- Sinuous Tail 03 M
- Sinuous Tail 03
- Sinuous Tail 04 M
- Sinuous Tail 04
- Sinuous Tail 05 M
- Sinuous Tail 05
Good thing they just had a gift card sale...... Excellent product!
Thank you! (and I took advantage of that excellent gift card sale too
Number two on my monster must-have list!
Cheers,
Alex.
Thanks!
Insta-buy. Excellent
Awesome! I hope you will like it.
Definitely need this to go with the wyvern. Thank you!
You're welcome!
Straight into the shopping cart.
Cheers,
Alex.
And it is released! You beat me to it. Thanks for the support!
My three favourite DAZ Studio releases so far this year: Hershel Hoffmeyer’s Wyvern, Howie Farkes’s Ultrascenery and RSA's pose control for the wyvern.
The pose is from RSA's set.
There's a 6K version here: https://www.deviantart.com/efredrules/art/The-First-Law-Of-Thermodynamics-Part-2-837411482
Cheers,
Alex.
Thank you so much! I am glad you like it!
Used one of the poses along with 3 of the scripts to get this beast to fit in between the trees!
Oh nice! I had admired that promo in the HH Wyvern thread. Very good job!
I am curious for anyone who has this product. What do people think of the Convert Poses workflow? Not necessarily the conversion itself, as I know that is not the best with some poses. I am curious what people think about converting-on-the-fly, with the bone minion always available? That there is no saving converted poses to your HD filling it up? Or is it inconvenient? Convenient? Would you have rather a more traditional, convert, save, use workflow?
Hmmm I got a chance to play with this a little today and if it was a full 100 % convert I can see the usefulness of not having to save the poses out, even if it was only just minor tweaks to areas. But so far with the poses I have tried with the Wyvern theres going to be some major adjustments with areas. Not that that is unexpected since its two totally different beasts.
See attached, I have included a Dragon 3 with the pose I used. And the posed applied to Wyvern.
This one worked pretty good I think. All it needs is some toe adjustments.
Also while im thinking about it, I had trouble with the Lock bones script when I tried to unlock the bones I had locked. I do need to check this out further it might have been a one off or gosh forbid a user error
Ok so I decided to read the manual on the Lock Bones, thats usually helpful lol. So now I know its how its programmed but as a suggestion maybe it seems more intuitive that when say the feet are selected in the preview if you click the Unlock Selected with Children should unlock the bones to that area. Those buttons work in the tree menu when the item(s) are selected but doesn't on the body parts area.
Oh and Thank you for including the scripts and poses they are great!
