When clothes appear as grey cubes, why?
Why does this happen at times and how do you undo it? If you delete the clothes and add them again to scene/character they come in again as cubes. This seems to happen randomly and just often enough to be annoying...
This usually means the geometry files are missing.
Are you getting error messages about missing files when you load them?
Are these V4/M4 clothes being auto fitted to Genesis 1/2? V4/M4 clothes on v4/M4? Genesis clothes on Genesis?
Have you moved or rearranged any directories in you content libraries?
G2 clothing for G2 character.
It appears after file the anumber of renders may have been made etc... without any swapping in and out of characters etc. I just open the scene and there are cubes.... Most times I can step back to a previous scene but saved as a different file name... and things load fine.
Sometimes I do get a an error message regarding location. But I'm a little confounded as I barely know where those files are and I don't shuffle that stuff.
Have you checked the log file Help > Troubleshooting > View Log File
What scene format are these, DAZ or DUF?
I will try that.... and report back
Always Duf... I didn't know that there a choice to save in another format
problem gone... the only thing that has changed is that I restarted my computer a few hours back... maybe it's a hardware issue??
What kind of drives/partitions do you have? What operating system?
I could see it happening if some of the folders are on a separate drive/partition/network storage device that isn't available/has spun down.
DAZ is the older format, and is saved a different way. You can't save as DAZ in the newer versions, I was just checking.
win8
i have one external dinosaur driver (dont use it anymore)
2 hhd hard drives, and 2 ssd drives...
So should things be where both scenes and program operating system are on comparable drives
My guess is that what ever folder they are in is on a drive that is "spinning down"/'sleeping' so when it is being run the cached files can't be found. But restarting/rebooting will clear and repopulate the cache, so will loading in a new scene (same content, different name...different cache 'folder').
This is an OS level problem...so check your timeouts/sleep times in Windows...try "NEVER" for any disk based drives and whatever the SSD manufacturer recommends on all SSDs.
Aww...makes sense! Thanks for the answer you are spot on....
