mcjBoxUV: make usable UV maps: DS1-DS4.5+
2»
    That looks really amazing!
  • mCasualmCasual Posts: 4,607
    well i'm having problems with the Daz Studio 1 and daz studio 2 version
    when dealing with polygons that have more than 4 sides
    for example i get a poly, marked as having 5 edges, but when i try to access edges[] it's not there
    i'll leave it at that for now and publish all 4 new versions incessantly
    edited February 2014
    ** Important Update ** Important Update ** Important Update ** Important Update **
    https://sites.google.com/site/mcasualsdazscripts3/mcjboxuv
    Important bug fixes for the Daz Studio 4.5+ version
    and new features ( scale and template size )
    and a version for Daz Studio 1 & 2 and Daz Studio3 ( and DS 4.0 i think )
    History
    February 16th 2014 9:25 am major fixes and features + versions for DS 1, 2, 3
    February 13th 2014 9:33 pm fixed template generator for flat plane objects
    February 13th 2014 released
    884 x 686 - 93K
    1120 x 364 - 78K
    Post edited by mCasual on
  • DollyGirlDollyGirl Posts: 2,717
    I want to thank you Casual for your script. I have been creating some spline objects and using your script to uv map them for a better result. Getting good results, consistent and reliable. Here are some of the things I have made so far. Thank you so much for this "little" script. Love it!
    800 x 1035 - 448K
    welcome, glad it gets used ! i used it a few times too
    similar to this, recently i added mcjPlanarUV and mcjSpericalUV
    https://sites.google.com/site/mcasualsdazscripts4/mcjplanaruv
    https://sites.google.com/site/mcasualsdazscripts4/mcjsphericaluv
    this hat was re-UVed using mcjSpherical ( with the camera at the center of the hat )
    1280 x 720 - 246K
    I will have to take a look at them.
  • SlimerJSpudSlimerJSpud Posts: 1,456
    Thanks for this! I also have a prop that desperately needs a proper UV map. Will give this a shot. :-)
    there was also mcjPlanarUV and mcjSphericalUV
    they were not added to the main index pages but are
    here
    http://www.daz3d.com/forums/discussion/43295/
    and here
    http://www.daz3d.com/forums/discussion/42361/
    800 x 600 - 203K
    here
    and here
    Actually, All that part of the prop needed was to use MCJBoxUV to export a decent template. Then I could texture it properly. I also used MCJLathe to create a new base for the prop. So Easy to use!!! :-) I've released it as a freebie on ShareCG. The announcement is here:
    http://www.daz3d.com/forums/discussion/44324/
