How to white out the eyes on Genesis 8?
Hey guys. I am trying my hand at making the comic character Lady Death. But I cannot figure out how to white out the eyes. Tried rotating but they dont go all the way and some part of the iris is always visible, despite reducing the size. Setting the opacity of the pupil and iris all the way down didn't accomplish it either. Any tips?
ALso attached a pic of the character. If you have any hair or clothes recommendations let me know! I am in the early stages currently
  • RawArtRawArt Posts: 6,241
    I would put a white shader on the "eye moisture" surface
  • MuzMelMuzMel Posts: 76
    Thanks for the response! Did you mean setting the base color to white? It did not work for me
    edited March 2020
    nope....finding a shader that has a nice pearly white look, or plastic look, or whatever you like. Simply setting the base colour will still keep it as transparent as if it were water.
    The idea is to make it solid looking to hide all the sclera and iris details below it
    Post edited by RawArt on
  • blainemillerblainemiller Posts: 59
    Also, you mentioned the eyes not rolling back... there are built in parameter limits that can be overridden. Click the gear icon (immediate far upper ight) above the parameter you wish to modify (in this instance the rotation of the eyes). When the menu appears, sellect the first option — parameter settings. Adjust as you wish. In this case, I suppose you could do -179 and 179, but 90-100° should get you there. Upon closing the window, your parameter slider will reflect the new settings, allowing you to slide it further.
