Long render of fur
EdpaEdpa Posts: 46
edited February 2014 in The Commons
Please help me. I'm trying to render fur bolero in DAZ . Here from Imaginative 3D store
But I dont understand why I have long render. Usually things happen quickly - less than 1 minute.
To example my render
Post edited by Edpa on
    In DAZ what?
    What are your render settings?
  • EdpaEdpa Posts: 46
    DAZ 4.6 . Default render settings + 2 lights
    Studio 4.6 then...DAZ is the company name, Studio, Bryce and Carrara are all DAZ products.
    Displacement will, to some degree, increase render time...and that is using a ton of displacement. There's also the possibility that there are some transparency maps coming into play...which will also increase render time.
    Post a screenshot of your render settings.
    These or material settings in Shader Mix?
    855 x 1005 - 54K
    Turn the Max Ray Trace depth down to something like 2 or 4...you don't need 11 bounces.
    My thanks,Addict
    Edpa said:
    My thanks,Addict
    You're welcome...New Member.
  • JaderailJaderail Posts: 0
    mjc1016 said:
    Edpa said:
    My thanks,Addict
    You're welcome...New Member.ROTFLMAO!! Great one...
  • YudinEdYudinEd Posts: 90
    :lol:
    Post edited by YudinEd on
    ;-P
    I saw the wrong way. It's looks funny. Of course, mjc1016. Thank you.
    :) New Member
  • RKane_1RKane_1 Posts: 3,039
    I'm not addicted....I can quit at any time I w...OMIGODDIDYOUSEETHENEWRAWARTTHINGEEINTHEDAZSHOPMUSTGOBUY!!!
    I set the value 2 in Max Ray, but render became a little shorter and the quality is worse. Maybe I can remove something in the material settings?
    Screen from Shader Mixer
    1884 x 919 - 269K
    No...adding things like displacement, raytraced shadows,transparency mapped hair (especially with raytraced shadows) WILL increase render time...it is perfectly NORMAL for that to occur.
    That particular item uses a massive amount of displacement mapping. For every strand of hair that is on the jacket, calculations need to be made to move parts of the geometry out from the surface...this will take time.
  • Richard HaseltineRichard Haseltine Posts: 112,009
    Try using the progressive render settings in the Advanced tab of Render Settings - I've been very surprised at how much faster it can be in some circumstances, and scenes with a lot of geometry are one of the times it's meant to have an advantage.
    You can disconnect the velvet and granite nodes . Change lightning model in DAZ material - skin to plastic. I do not give a guarantee that render will faster, but the fur quality will be worse.:) How long your render? It makes sense to change something? My rendering takes a bit longer than 3 minutes. I have not powerful computer. I suggest next time to contact me by email. You have it in the readme or contact directly in 3D store with questions about the product.
    Thank you all.
    Yudined, next time I'll do so - I'll write an email. I did not think about it. I like your clothes made ​​in Marvelous Designer. You do not want to make clothing for Poser and DAZ? In Imaginative 3D store I have not found anything except fur bolero.
    That looks similar to the fur shader I did ages ago...what is your shader rate?
    Changing the shader rate will change how fine the fur looks in the final render and can be adjusted in the render settings.
