Hair converter for G8F to G8M
Female to male G8 Hair conversion. Some of the female figures have long hair styles I want to use on a male figure.
Just load up the hair and then change the scene identifier to genesis 8 male and then save and then fit as normal. Either that or just position it and then parent the hair, both ways work well.
I have tried changing the Scene Identifier, but for some reason, the hair sits lower on G8M than it should after fitting to G8M. I'm not sure how to address that.
I have the problem going the other way. I'm trying to fit a G8M hair to a G8F character and the hair sits higher up. I've tried unparenting it and manually positioning it lower, but it won't budge.
Possibly the best ways, if you can afford it, is the Daz Cross-Figure kit. It puts morphs into the item that lets it fit more or less properly to characters of the opposite gender. Works for both clothing and hair.
