Detailed crows or ravens?
Any advice on locating detailed models for crows or ravens? I've used LoREZ Crows which work brilliantly for background crows but would love to render a crow with a bit more detail, feathers and all.
  • GordigGordig Posts: 10,805
    The crow in Songbird Remix Characters looks pretty good. The page doesn't specify that the original Songbird Remix is required, but I would assume that it is.
    edited March 2020
    I have this and it's not. Sadly, the birds are 3Delight and don't convert well to Iray due to lack of all the different maps. I'll pull one up and do a couple shots.
    *edit* Oh, wait...I have the Corvus - https://hivewire3d.com/songbird-remix-corvus-corvus.html which is apparently a bundlle of the Songbird Remix crows and ravens.
    Post edited by MelissaGT on
    Here it is -
    1059 x 904 - 52K
  • JOdelJOdel Posts: 6,322
    The artist is in the process of updating all of his bird models (something like 1100 of them) and re-releaseing them with Iray and Superfly as well as 3DL and Firefly materials. Not sure whether he's reached his crows yet. But if you already have them it will be a free download when the updated versions are released.
  • davesodaveso Posts: 8,258
    where will they be available?
  • scorpioscorpio Posts: 8,533
    Hivewire
  • GreymomGreymom Posts: 1,147
    Thank you for the infomation on the Songbird Remix updates!  I will be watching for that.  Have so many of the series, and would like to use them with IRAY or Superfly (and Superfly shaders should be easy to convert to Blender).
    The artist has a program of being able to transfer purchasing info on his models to Hivewire. You'll need to send a screenshot of the purchase history here. Once you've done that, you can check bac through the store to see which volumes he's already re-released.
    Many thanks!
  • JeremyDJeremyD Posts: 265
    edited March 2020
    Dbl post
    Post edited by JeremyD on
    edited March 2020
    Appreciate the responses! it's been a while since I've shopped Hivewire.. I'll give them a browse. I also started looking at sites like TurboSquid which also sells crows. Some of the models are $300. The models look beautifully detailed but dang.
