i13 HQ Bathrobe Crash on G8F
Hoi!
https://www.daz3d.com/i13-hq-bathrobe-for-the-genesis-3-female-s
I wanna use this bathrobe on my G8F, it starts already with the weird problem that it never autofits (not even on G3F, it dont have a fit to autoscript), so I have to select it always and do it self.
But... at G8F it crashes :(
It stucks always at that part.
"Building projection map..."
Can someone test it too? maybe my installaiton is just broken, maybe its ... absolute not aviable for G8F ? :( its sadly the only bathrobe I have which I can open, my other ones just have stuff like "show breasts" which I dont care^^.
(and why have no bathroobes a hoodie :( )
Update during creation: it completed it :o it seems like the fitting is very very slow, so can someone test it too if he/she own that product?
  • SevrinSevrin Posts: 6,314
    If you click inside the Daz window, you usually get the Not Responding thing added to the active window title.  I just tried this item and it loaded normally on G8.
  • rames44rames44 Posts: 336
    I don't have the product, but here's a trick that may or may not work. The idea is to get around some of the auto fitting stuff.
    1. Make sure your G8F is NOT selected in the scene - don't have anything selected.
    2. Double click on the product to bring it into the scene not fitted to the character.
    3. Select the garment in the scene.
    4. From the hamburger menu (top left of the Scene pane), Find the Scene Identification menu item
    5. Change the figure association from Genesis 3 Female to Genesis 8 > Female and save
    6. Now right click on the item in the scene pane, select Fit To, and select your character
    Essentially, this tweaks the item so that it thinks it's a G8F piece of clothing instead of a G3F one, which means that DS uses a different method of fitting it to the character. This might cut way down on the work it thinks it needs to do.
  • LoonyLoony Posts: 1,817
    Does the item autofit automatic for you? or have you to fit it by hand?
    It fit okay for me without intervention.  Morphs still worked.
    hmmm okay :/
    Then my file is bugged :/
