ISO a working Move Origin Script for DS4.6
StratDragon
Move Origin from Delta X1 appears to be the only script that does what I need it to do with some props.
The Joint Editor is hit or miss on most of what I'm doing and causing more problems than it fixes
also there was another script someone pointed me to and it's not working and I don't have it in front of me and forgot the name.
Does anyone know if Delta's script can be modified to work in DS4.6? When I select it now the dialog doesn't even come up. I loved this script and it was a major part of my workflow.
The copy I just downloaded seems to work in 4.6. The hard part was finding it since the forum archives aren't up. The copy I found claims to be version 1.5 with a date of 27/09/06.
I need to check my version. thanks for the validation on 4.6
over here http://www.daz3d.com/forums/discussion/33617/P15/#509470
there's my recent script which lets you move the origin and change the "orientation" of nodes
in most cases i still ise Delta;s script
the repository i use is
http://www.4shared.com/dir/722776/10801f63/DS_Scripts.html
