Is the new DAZ CAT finally here???!!!
14567810»
  • jewels99jewels99 Posts: 30
    I had a rough time getting the hair to show up on this cat.  I ran the d-force simulation, but it didn't work correctly.
    620 x 596 - 716K
  • XelloszXellosz Posts: 855
    edited March 2020
    Oso3D said:
    I did the fur, though other artists did work on this, too.
    Why do fur and not a new figure?
    Have you ever made a completely original figure? It’s really hard. :)
    Plus making it look right is REALLY hard, particularly with discerning cat lovers.
    I’m hopeful that eventually we will see a new cat, but until then...
    If you want better hair, you can decrease Line width and increase Hairs per cm2. But you will increase render load... so it depends on how good your machine is. (I picked values that worked reasonably on my ok machine)
    Further, you can change line tessellation to 3 to model actual full hairs. But that triples the effective polygons. Again, if your machine is spiffy...
    Another way to make the hairs look more ... fine is to lower cutout. I’d suggest experimenting with a value around .6.
    I believe old textures should work, as well as any weird MilCat textures you may have. Just go into the fur surfaces and replace the obvious.
    Try what Oso3d suggested it might help a bit, but it's a bit more resource heavy on the PC.
    Post edited by Xellosz on
    Xellosz said:
    What would happen if the cats would would be hoarding up items too???
    Well, it would make a change from the usual Andrex Puppy...
  • ANGELREAPER1972ANGELREAPER1972 Posts: 4,820
    thought I'd risk it and share hopefully doesn't get me banned know it would in the galleries here's
    the cat's meow
    Image may contain: 1 person
    2646 x 1589 - 1M
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,418
    nice kitty heart
    mine don't steal the roll, they just shred it
