Adding to Cart…
Absolutely amazing work, AM! I have been watching your progress with this one on your Facebook page. Absolutely amazing every step of the way!
Tim
Thanks to you for the kind words. Cheers!
You're welcome.
@melissastjames Then both of ours were being wonky because mine was doing the same. But GPU-z showed more activity on the GPU during render than task manager did. Thank you for the info. I can fill you pain on the GPU decision I had a hard time deciding also. If I had know I would dive back into the 3d world like I have I probably would have made some different decisions at the time but I was only gaming then.
@Alessandro Mastronardi I have yet not been able to render the dforce version at all. Its irritating because everything that seems to max out my memory crashes the whole computer and so I have to wait for it to restart and it stresses me out cause I know that cant be good for the computer either. Makes me wonder if something is not set up right. Anyway off to play some more and see if I can get it to work. But I can still use the catalyzer version so all is good.
I was watching it on my NZXT CAM software, which is what is needed for my AIO cooler. I'll have to consider installing GPU-z again...haven't used that in ages. I try not to have too many hardware monitoring programs as sometimes they don't play nicely with each other.
On your crashes, have you checked your Windows update history? I literally just had to do a full reinstall of Windows yesterday (before I got back up and running and rendered this kitty no prob). My friend sent me an article she found that apparently there is a really bad update that just dropped on 2/27 that is causing system crashes and bad behavior to the point of not being able to boot. I had very similar symptoms to yours (crashing while rendering) before my system just up and NOPED right into not being able to boot at all. Might want to check to see if you have update KB4535996 and if so, uninstall it. I'm not sure if I can link to it here, so remove if necessary, but here is the article -
https://lifehacker.com/if-your-pc-is-struggling-to-boot-uninstall-this-window-1842155080
That update is not installed, thank goodness! I ordered more ram suppose to be better than what I am running and will put me at 32GB. If im still crashing then Ill have to pick things apart til I figure out whats going on. So im crossing my fingers that it all works out because I really want to render this beatiful creature at full potential!
Just purchased it and I am actually finding it to be a lot less of a strain on resources than I expected, at least for the dforce SBH version. i am glad AM went with the populator version instead of the more common fatalis.
My first attempts! The first two are done with Dforce, the last two with the catalyzer, which I find easier to use and it also seems to render faster.
The emperor's zoo in Sirenopolis has a quite deplorable safety record. His latest acquisition has managed to escape after only a few hours and is now prowling the streets of the city, looking for lunch. If it's unlucky, it will soon bump into Archmage Serena, senior enforcer with the sisterhood of the Future Mages. If it's really unlucky, she'll be in a bad mood.
Cheers,
Alex.
Great renders Alex, I like them all. I must say probably the lion-like fur pattern is the one I like more.
Finally got it to work. Had to change "5" to "3" and render in "safe mode." Just love this guy!!!!
Awesome as always! Thank you Alessandro!
Grabbed both the Smilodon and the Companion pack, cant wait to test them out!
Glad you like it guys, and the images you do with it are great!
Alessandro, this is absolutely fabulous. Love the details I am able to obtain. This is your original felidae combined with the fur from the smilodon populator.
Well done and yes, one can mix shapes at will...
I found that if I load the Smilodon figure with the default fur, my machine crashes. But...if I load the figure and delete the attached fur, let the Iray viewport render, and then use the "hair" option to add fur, I am able to render. I imagine that there is something about the default grouping of figure and hair that eats the last bit of memory, while loading them separately avoids the grouping issue. In fact, the render doesnt take long. I tried to use the LAMH catalyzer at first, but I got an error message saying there was no item to run the catalyzer on. Apparenty only a dForce option, which I just let the generic pose work for me. In fact, my workaround did not take much extra time, and rendered in full fur (added separately) with regular Iray in about 3 minutes. I don't have all the specs to hand, suffice to say DAZ 4.12, and a brand new gaming computer with plenty of memory to run games. The Smilodon model by Alessandro is quite a handsome creature. I remember seeing saber tooth tiger skulls at the George Page Museum down in Los Angeles, taken from the La Brea old tar pits.
I can confirm that loading the catalyzer version crashes Studio for me, and, after checking, I see the same thing happens with the gnu, though not with older models like the fox. I reinstalled the plugin to make sure I am running the latest version, but it shows as 1.8, not 1.9, so, I am not sure what's happening with it (it also doesn't show as installed in DIM, it only shows the user guide, which is very weird and only started occurring recently). It's not a critical issue, as the dforce version works beautifully, but it may be an annoyance when I render it with figures that only have a catalyzer version.
I'd have to take a look at the Catalyzer log files to understand what's happening, so if you like feel free to email those to me folks...
Sure! Here's the log after trying to load the smilodon, thanks for looking into it.
Ok I will need also the Catalyzer log file (look in /Documents/DAZ 3D/Studio/LAMH2Iray Catalyzer/LAMH2IrayCatalyzerLogFile.txt), but please email them at [email protected]
Thanks
Done, sorry about the mixup.
Thanks, no problem!
Ok, so with @Uthgard the issue it's fixed and the loading issue was caused by an outdated Catalyzer version. So, @IceScribe and all users with issues might want to check out that Catalyzer version needs to be 1.9 (go to menu Help->About Installed Plugins, click on LAMH Catalyzer and verify the information). If version it's not 1.9, run the DAZ Install Manager and update it. If that doesn't work (sometimes the Install Manager fails to run updates), contact me at my email (see my signature).
Woohooo!! Ram came in and installed, I am able to use the dforce version now!! I haven't tried to up render settings or anything but I think it will be ok because once it started rendering it was good to go it just never made it that far.
Catalyzer version I can render at density 4 but anything above that causes a crash.
But 4 is better than 3! Of course I dont think i would be able to render with anything else in the scene with either.
Did do some editing, lightened the image changed the color saturation some then had to do desaturate the mouth because it looked like it was glowing (probably my fault
) Rendered with default low settings dome on and a basic plane for the floor.
Looking great, Alessandro!
And I see you have the Wolverine available, too! I can't wait to get them both!
Only a matter of time before someone begins posting fight scenes between Wolverine and Sabertooth--just be careful you don't get sued by Marvel Comics.
Wait...no outfits for these guys!?
