How do I use dForce with primitives and figures?
I purchased "dForce Tutorial Set : Fantastic Voyage!" and tried to recreate the examples shown (making a cave, skin indentation), but when I click 'simulate' in the simulation settings tab, it tells me there are no objects to simulate.  I'm pretty sure I followed all the steps in the videos.
For the skin indentation, I loaded a G3 figure and a primitive sphere from the create tab. I made a 30-frame animation sequence in which the sphere moves into the figure's body, exactly like the presenter did.  Still it tells me there is nothing to simulate.
  • SevrinSevrin Posts: 6,314
    You need to add a dForce modifier. The attached shows the most basic way.
    698 x 881 - 77K
  • Hmm... I don't seem to have that option in the dropdown list.
    738 x 574 - 38K
  • I found the option to add a dForce modifier in a different location (The button with the lines right next to Simulate), but now the program crashes whenever I try to simulate it.
  • kenshaw011267kenshaw011267 Posts: 3,805
    Try this simple experiment.
    Create two primtives
    1) a plane with lotas of subdivisions, 200 at least.
    2) a cube or sphere. Place it below the plane.
    put a shader on each, contrasting colors are best.
    Select the plane add a dForce modifier:Dynamic Surface
    Simulate. If produces an effect of a sheet on top of a table, or ball, then you've done it right.
    If that doesn't work then you might have an issue in your settings or computer that need to be worked on.
