Changing file association
Is there anyway at all to change the new dson of duf files back to obj files.Reason being I have just gotten my Stitch Witch reloaded again to start making textures for outfits.I am a beginner in this process but would like to learn to make these textures.The programme only seems to use obj files to make a template.So I am stuck in the mud so to speak,and not having a very technical mind I can't for the life of me figure it out.
  • Richard HaseltineRichard Haseltine Posts: 111,921
    For that I would think just File>Export and set the format to OBJ would work, it prsumably just needs the UV mapped geometry.
  • But how do I do that I have no clue.Where do I find file export,and what is the process.
    edited March 2020
    New to computers? Most programs have the File save options in the same place. Have attached a couple of images for you.
    Then in StitchWitch select the option to extract a template and load the .obj file.
    389 x 394 - 20K
    491 x 574 - 40K
    Post edited by Catherine3678ab on
  • Thank you so,so much Catherine for your awesome help.In the meantime lastnight I found a programme that does it for me.So now I am away laughing (so to speak).
