Help need with 2 shaders (a Translucent Shader & a Thick-ish Liquid)
Turk_WLFTurk_WLF Posts: 177
I’m trying to make a translucent shader similar to a Windshield Washer Reservoir
( http://blog.bavauto.com/wp-content/uploads/2009/11/1b1.jpg )
Also I need a reddish brown heavy or a thick liquid like Motor Oil or Syrup, I need I could start with Water but I’m not sure how to do the “thickness” look.
Thanks,
    Thanks,
    Probably under transparency. You'll want to try in-scattering and/or absorption. You can set colors in those channels to help drive the color. If I recall, a light color will drive a stronger effect and a darker color will be a less strong effect. Unless I'm remembering it backwards.
  • McGuiverMcGuiver Posts: 221
    edited February 2014
    This shader tree should work for the liquids......just change the color in the transparency channel.
    Below is a pick where I used yellow to make a honey look.
    Color = black
    Alpha = none
    Highlight = value 32%
    Shininess = value 51%
    Bump = none
    Reflection = fresnel term10%, Ray Depth 2, Max. attenuation 85%, Blurry reflections off
    Reflection shader = value 11%
    Transparency = fresnel term 10%, Ray Depth 4, Max. attenuation 85%
    Transparency Intensity = color Yellow (or what color you wish)
    Transparency Absorption = none
    Transparency In-scattering = none
    Refraction = material (other) value of 1.10
    Glow = none
    Subsurface Scattering = none
    Translucency = none
    1000 x 775 - 256K
    Post edited by McGuiver on
    Color = black
    Alpha = none
    Bump = none
    Glow = none
    Translucency = none
    Here's a list of IOR values...
    http://www.pixelandpoly.com/ior.html
