Shape preset only.. .no option to dial in the setting ?
Kharma
in The Commons
I have Milly for Josie 6 by Belladzines and all I can find is a shape preset, there are no dials to set to only a certain amount of the character. Is this normal or do majority of vendors to both a full shape preset and dials so you can add a little or alot of the character?
I don't have her, but if I select a G2F character I have a bunch of dials for other G2F characters.
So at least it is not the norm.
Could it be that she is reusing Josies body, so it is only a head morph?
I searched through every dial setting and used the search function and couldn't find anything for Milly. I also have lots of other dial settings for characters, this must be the first time I have searched for dials on a particular character and couldn't find any .. neither head nor body that's why I was curious to know if tis is an one off case or if there will be others with the same setting ...
Have you tried applying Milly, and then go to Currently Used. Then you should be able to see which morps there are applied.
What you can do is
Thanks Richard! If the morph is for full body is it possible to do the steps you outlined and save out a dial for each of head and body or would that only be possible if there was already a shape preset for each separately?
You'd need a shape preset or to manually split it down yourself, assumng there were separate morphs for head and body among the ones used.
