Shape preset only.. .no option to dial in the setting ?
KharmaKharma Posts: 3,214
I have Milly for Josie 6 by Belladzines and all I can find is a shape preset, there are no dials to set to only a certain amount of the character.  Is this normal or do majority of vendors to both a full shape preset and dials so you can add a little or alot of the character?
  • felisfelis Posts: 6,605
    I don't have her, but if I select a G2F character I have a bunch of dials for other G2F characters.
    So at least it is not the norm.
    Could it be that she is reusing Josies body, so it is only a head morph?
  • KharmaKharma Posts: 3,214
    I searched through every dial setting and used the search function and couldn't find anything for Milly.  I also have lots of other dial settings for characters, this must be the first time I have searched for dials on a particular character and couldn't find any ..  neither head nor body  that's why I was curious to know if tis is an one off case or if there will  be others with the same setting ...
    Have you tried applying Milly, and then go to Currently Used. Then you should be able to see which morps there are applied.
  • Richard HaseltineRichard Haseltine Posts: 111,875
    What you can do is
    1. apply the prset to a zeroed figure
    2. right-click in the Parameters pane and select Edit Mode (assuming it isn't already checked).
    3. right-click in a suitable group - e.g. Actor>People>Real World or whatever you find other character sliders under
    4. select Add Property (or possibly New Proeprty, I can't recall)
    5. enter a name (e.g. BD Milly J6) and possibly set the minimum value to 0
    6. click Accept
    7. set the value of the new property to 100%
    8. right-click on the new proeprty and select ERC Freeze
    9. run you eye down the list of Sub-components to make sure there are no interlopers
    10. click Accept
    11. Test that the slider does allow you to vary the amount of Milly applied to the figure
    12. optionally File>Save As>Support Assets>Morph Asset, in the options dialogue select your new Milly slider, check that the base content directory at the top is the one you want to use (that it's one that gets backked-up for example) - the Author and Product names will be used for folder names inside /Data/Genesis 2/Female/Morphs/ if you need to find the fiels later
    Thanks Richard!  If the morph is for full body is it possible to do the steps you outlined and save out a dial for each of head and body or would that only be possible if there was already a shape preset for each separately?
    You'd need a shape preset or to manually split it down yourself, assumng there were separate morphs for head and body among the ones used.
