Tops too form fitting on my busty Genesis 8 figures
comixfana
in The Commons
I've found this product https://www.daz3d.com/sy-universal-breast-helpers-genesis-genesis-2-and-genesis-3-female-s
But would it work for Genesis 8? Better yet, is there a version of this for Genesis 8?
Thanks
Sweet, thanks!
Mesh Grabber can help with this too. Sometimes, when using Fit Control or similar sliders, I can't quite get things where I want them, so I'll use mesh grabber to fine tune things. It's a bit of a blunt instrument sometimes, but is usually quite helpful.
Mesh grabber can be particularly helpful if you are dealing with string monokinis and such, and are trying to achieve a 'perfect' straight line between the nipples and the waist and the product in question wants to do the shrink wrap thing instead... There's a bit of fiddling involved of course, but then fiddling is already something you need to do sometimes in Daz Studio.
Might be worth trying to dforce the item too, or use in conjunction with mesh-grabber.
If mesh smoothing is on and at a high setting value, turning it back to 1 also could help
+1 for mesh grabber, great help
Dforce can certainly help drape the fabric in a more realistic fashion.
