Seeking City Building asset to place outside a room's windows
Hi, I have a location asset, it's a room with windows. When it renders the windows are transparent. The room should exist in a city, so I need images of buildings to place outside on the window layer.  The camera might be set at various angles so I think the buildings should probably be a 3d assets in order to match the camera angle, but they dont need to be super high resolution. Is there a city asset that  fits the bill? Thanks
    If you are using Iray, you could put a nice image on the render/sky Dome and set it to draw Dome.
  • macleanmaclean Posts: 2,438
    Maybe Streets would fit the bill. A dome image is certainly a lot cheaper, but 3d assets you can see, make it easier to position things and get the correct perspective. And of course, they can be used for other things.
    Note - If you're not in a hurry, I'm pretty sure Streets will be on sale during March Madness,
  • heisdaveheisdave Posts: 130
    thanks, I check out Streets, it is a step in the right direction... but with Streets the city looks intact if you are on the ground looking up. But my windows are supposed to be a dozen stories high. Are there any similar assets that include a few intact buildings (intact at least from the side and top) that I can place outside the window?
  • mavantemavante Posts: 734
    edited February 2020
    Night and Day City for Daz Studio
    Modular city blocks. You can use as many or as few as you like, or even individual buildings.
    Post edited by mavante on
    Another option : If you use a camera with DOF , you could blur the background and even building coloured cubes could potentially do the trick (together with a nice simple skydome)
